Home > Technical Chat > Banjo fittings on turbo water pipes
Custard
Member #: 8215
Rayleigh
Hello..
basically, will m14x1.5 90* for 8mm pipe banjo fittings flow enough water for a gt17?
should make the pipe routing neater as its gunna be tight running a straight out barbed push on fitting.
Ta
Dave the Cake
I just opened the holes up a bit in my bolt. I even think I put 4holes in there.
Worked fine on the upside down skip.
tadge44
Member #: 2500
Buckinghamshire
Works fine on my car too.
nala56
Member #: 9661
Sheffield South Yorkshire GB.
And mine
Main Build
Upgrade to Turbo
Custard
Member #: 8215
Rayleigh
thanks guys got one turning up tomorrow!
Dave the Cake
