| Home > Beginners Tech > Turbo pistons? | |||||||
296 Posts Member #: 7876 Senior Member Walsall West Midlands WS1 2DW |
5th Jul, 2013 at 10:47:00am
Are these turbo pistons? TRW-175-9335-T +0.03 Cheers Steve Patina=old and knackered and won't clean up |
5th Jul, 2013 at 08:38:09pm
+30 thou? They must be old, the numbers dont ring any bells any idea what company made them? Yes i moved to the darkside |
5th Jul, 2013 at 09:40:50pm
TRW perhaps? On 13th Jul, 2012 Ben H said:
5th Jul, 2013 at 09:48:29pm
these and std overbore pistons and are crap they wont last 100 yards on boost ditch them and get a set of omegas
5th Jul, 2013 at 10:23:47pm
Not what I wanted to hear really but I did ask lol! they are already in a built up engine I am afraid that is going into my metro turbo which is pretty standard. I might stick the ecu back on if anyones got one and all the bits to see if they can last a bit longer! I really don't want to go down the route of having it rebuilt at this stage. Patina=old and knackered and won't clean up |
5th Jul, 2013 at 11:21:51pm
Iran standard metro non turbo pistons in my old motor. At 10 psi. Had it properly tuned though. Didnt seem to be any problems with it. So might be ok for low boost aplications. But as steve says omegas for peace of mind.... |
6th Jul, 2013 at 09:49:38pm
I have omegas in my mk1 n/a 1330 but can't afford to build another at the mo. Patina=old and knackered and won't clean up |
6th Jul, 2013 at 10:13:34pm
all the power the engine will ever make is above and on those pistons, seen it many times it always ends in tears by using chocolate pistons NOT up to the job.............. so get saving steve.
6th Jul, 2013 at 10:54:24pm
yes that's fair comment Benross and when southam build my other engine it was no expense spared but to be honest this is no performance machine its a bog standard mg metro turbo that's going to be driven sensibly. The engine has already done 17;000 miles apparently so its probably already f-cked especially as I bought it off ebay lol! I really need to just get the engine back in and running though as its in my garage instead of my mk1. Thanks for the advice though and I have taken on board what you are saying so may think about building up the spare engine for a swap over at a later date. Patina=old and knackered and won't clean up |
1170 Posts Member #: 8636 Post Whore Surrey |
6th Jul, 2013 at 11:30:49pm
ditch the turbo then buddy and run n/a
Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
