| Home > Technical Chat > Best cam to use on metro turbo | |||||||
321 Posts Member #: 10371 Senior Member leicestershire |
8th Jul, 2013 at 03:52:51pm
Rebuilding my metro turbo engine in my spare time and im at the point to put a camshaft in. it did have a kent 266 cam but dunno to use it or not so need some advice on should I stay with the cam Ive got or to buy another. Dosnt matter if it runs lumpy on tic over but needs to perform all round eg fast road,track day, and so on any advice would be greatful thanks |
8th Jul, 2013 at 04:53:22pm
This has been discussed many many times on TM. All you need to know can be found with a search I seriously doubt it! |
319 Posts Member #: 1742 Senior Member essex |
8th Jul, 2013 at 04:54:34pm
alot of people use the sw5 and the avonbar phase 2 turbo cam. My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901 |
8th Jul, 2013 at 05:40:28pm
Also alot of people dont use these.cams :) Yes i moved to the darkside |
8th Jul, 2013 at 06:17:52pm
Be4 others bite my tongue of yes I have searched as much info as I can but most people only want it for a pacific use and it mostly fast road and sound like im back to square 1lol looks like ive gotta look at some graphs and see where it leads me |
8th Jul, 2013 at 06:29:24pm
Get an Avonbar Phase 2. Was fantastic in the upside down skip.
8th Jul, 2013 at 06:38:05pm
Hahaha well im guessing the phase 2 it oiut of the questions and dunno how right this is but they performe **** with 1:5:1 rockers dunno how true that is but going on research |
8th Jul, 2013 at 06:42:43pm
We ran ours with 1.27 pressed steel rockers. Good for over 200 bananas. On 11th Feb, 2015 robert said:
8th Jul, 2013 at 07:35:58pm
If its just a road car and not revving past 6500
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
8th Jul, 2013 at 09:01:58pm
Any cam that needs a high CompRatio to function in NA mode would not be good, as you are going to lower the CR for the turbo most of the time. So you'd get a very anaemic off boost performance.
8th Jul, 2013 at 11:01:03pm
Well most of the time it will be on the road and putting people in there place but I be on the track as much as I can and yes your right sir yun it will be free but id rarther spend money and get it right so I dont have to strip the engine again been looking on some graphs and the best choice I can work out would be kent 276 would this be better than the 266 cam? |
9th Jul, 2013 at 05:37:42am
Yes
In the 13's at last!.. Just |
9th Jul, 2013 at 05:00:22pm
Why do you reckon the 276 is better than the 266 ?
Edited by Sir Yun on 9th Jul, 2013. That sir, is not rust, it is the progressive mass reduction system
17th Jul, 2013 at 11:52:39pm
Thats true and I suggest it as the 286 would be good but the power band starts from 1500 to I think 6500 but the 276 has it from 1000 to 6500 but I dont think the 266 has not enough lift
18th Jul, 2013 at 02:11:41am
The 286 will be utter shit. Stick with what is proven to work, forget everything you know about what works well on N/A because this doesn't apply to boosted engines for cam selection. Sw5, Mg metro, 266, avonbarphase 2. Take your pick from those, those are the most used cams on here for a reason! On 26th Jan, 2012 Tom Fenton said:
18th Jul, 2013 at 05:33:02am
On 9th Jul, 2013 Sir Yun said:
Why do you reckon the 276 is better than the 266 ? It is very hard to compare camshafts just by looking at the numbers to be honest you can have a cam that is 100% identical on paper that is totally different in actual lift profile (the 276 was apparently just a numerical mid way point between the 266 and 286 and not really developed like the other two ) just to illustrate . same numbers two different profiles. difference is that one of the cams has 30 degrees of dwell My limited experience (NA) with the 276 was tepid at best. I'd easily take the one with the least jerk. Goes without saying really... On 13th Jul, 2012 Ben H said:
18th Jul, 2013 at 11:08:30pm
Dear lord what ever you do do not fit a 286!I made the catastrophic mistake of fitting one just because I had it and it made me utterly hate the car. I have the n/a MG cam fitted now and the car drives divinely on the road and gave me what I needed to see of a Mk6 Golf gti in MK! That can't be a bad thing. Own the day
18th Jul, 2013 at 11:48:36pm
Ok thank might as well stay with what I ve got then as like it been said it free as I have 1 so I cqn spend more money on sum where else that needs it |
![]() 538 Posts Member #: 9393 Use the search function before buying stuff from me... stoke on trent |
19th Jul, 2013 at 05:04:59pm
Do avonbar still produce the phase 2? |
1170 Posts Member #: 8636 Post Whore Surrey |
19th Jul, 2013 at 05:13:37pm
dont forget the MED T3 cam is essentially the same
Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
19th Jul, 2013 at 05:21:46pm
Yeh I wouldnt bother lol never had a problems with med
19th Jul, 2013 at 08:13:39pm
I can rember when avon was shutting down people where going crackers as they were selling off
