Home > Wanted > URGENTLY needed - 16 tooth speedo pinion gear
welshdan
Member #: 1111
s wales
i have been having problems with my speedo not working. not good. so stripped the speedo housing off the car this evening, the 7/17 setup that I currently have seems not to be suited - the 17 tooth pinion has stripped its teeth. it was tight going in. I have tried a few 17 tooth replacements that I have, they are tight also. have tried a 15 tooth one which feels ok, obviously this would make the speedo massively over read.
so I am going to try a 16 tooth one - only problem is I need the car Friday and over the weekend as im going out and about in it!
has anyone got a spare 16 tooth pinion? that could be posted very quickly? beer tokens waiting.
I really hope someone can help me out.
Cheers, dan
welshdan
Member #: 1111
s wales
or local would be good for collection?
cheers, dan
WRLondon
Member #: 8636
Surrey
ill have a look bud
know ive got a new one knocking about but not sure on how many teeth it has
Reading up on RTS Clutches
welshdan
Member #: 1111
s wales
cheers, have this sorted now. thanks, dan
