Home > 998cc > Skimmed 12g295 turbo ok?
jim4eva
Member #: 9626
Hi, I've got a 12g295 head, but it's been skimmed to 25cc... Will this be ok to use in a turbo project on a 998 engine?
It depends what compression ratio you're trying to achieve. If there is enough volume in the chambers at 25cc to give you what you want, then yes.
Phil.
jim4eva
Member #: 9626
Would I be better off getting my standard head modded? or a 12g202?
The 295 flows better than both those heads in standard form. The 202 can be made to work well but requires considerable work.
If the 295 is in good condition I would use this. If the chambers are big enough for what you need.
Phil.
jim4eva
Member #: 9626
Basically I want a daily driver that goes like stink... I dunno if this is a stupid question, but if I had the 12g295 ported, would that lower the comp. ratio?
sim_ou_nao
Member #: 114
Porto/Portugal
No *wink*
Pedro Silva
Porting the head has no effect on the compression ratio. Do you have the big yellow book "Tuning the A-Series engine" ? There's a good section on there explaining how to calculate the compression ratio.
Sounds like a good bit of research is in order.
Phil.
jim4eva
Member #: 9626
lol didn't know really... but the line of thinking was that there would be less metal on the cylinder head, and more space... It was a long shot lol
Porting is done to the ports. To reduce the CR material needs to be removed from the chambers.
Id be measuring the chambers first. You need to then work out the CR and decide how much boost you want with that CR.
25cc will be fine as long as you use 6cc dished pistons.
