Home > 998cc > water-methonal injection
minimongrel
Member #: 10419
Is anyone running a methonal kit on there mini? if so Pics?
Brett was, have a look at his thread in the "show us yours" section.
yes i was and still am, have it on the skyline atm though
i dont think i have many pics of the install though
http://www.turbominis.co.uk/forums/index.p...5648&lastpost=1
minimongrel
Member #: 10419
How much of a HP Boost does it give you?
here is a pic, you can see one of the the injectors and the control valve, i had this wired up to my ecu and had it running on a map like a fuel injector good results imo
Hp boost = non
a cleaner and slower burn yes
its a tool you can use to gain power, it will only give you power straight off if your intercooler is useless or your fuel is crap
using it as a tuning aid brings lots of gains BUT you when your water is used up your engine wont be far behind it
i would suggest having a good read up about it
good starting point
http://www.methanol-injection.co.uk/info.php
minimongrel
Member #: 10419
From my limited research i was under the impression that it would cool the Intake temp and add octane to the fuel. Im not sure what you mean if you run out your engine wont be far behind though.
minimongrel
Member #: 10419
Lolz, i found it you run out you blow up *Punch*
it cant cool the intake unless its already too high, and it is like running a higher octane fuel but here we are talking about 50 year old engines running carbs and clockwork dizzys, they need to be settup to run at the best, they cannot react to the real world never mind anything else, to get the most out of WI you need to run the engine beyond its limits for that you need technology and knowledge you also need to accept the fact that if anything happens to the delivery of the water the engine will be damaged
minimongrel
Member #: 10419
So I guess the best Question is "is it worth it?"
I'm using it, but haven't had much of a chance to fiddle with it.
As Brett says. You will not make any more power unless you change other stuff. Turning the boost up, adding ignition advance, etc.
wng691s clubby
Member #: 9252
Cleethorpes
i have it as a bit of a det preventor for running abit more boost than normal
Done now needs redoing lol
