Home > Wanted > wanted 1.3-1 or 1.27-1 cooper ratio rockers
jlay
Member #: 1742
essex
Hiya im after some rockers in good working order either some cooper 1.27-1 pressed steel ones (oval pad i believe) or a set of after market 1.3-1 rockers. Thanks James
My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901
Chalkie
Member #: 9764
Northamptonshire.
ones i gave you not right?
jlay
Member #: 1742
essex
They were the 998 ones which are ok for bushing but im after some cooper ones for the estate as they are higher lift standard.
You're mistaken. Coopers had the same rockers as every other Mini. The Cooper S however had special forged rockers, of ca. 1.22 ratio. The standard rockers with the highest lift, are the pressed steel ones with oval pads. They are approximately 1.28.
These are off 1275 engines found in 1300s, Allegros, Marinas, 1275GTs. Never in Coopers as these were all small bore in the 60ies and 70ies.
Edited by Vegard on 26th Jul, 2013.
jlay
Member #: 1742
essex
Thanks Vegard yeah i realised earlier when talking to a friend whos up on cooper i completely forgot they had forged even though i knew they were lesser ratio. Fingers crossed im sorted now guy on here has some. Thanks James
