| Home > Help Needed / General Tech Chat > Steering colum uj's | |||||||
26th Jul, 2013 at 07:50:40pm
Evening gents.
26th Jul, 2013 at 07:55:31pm
How about bringing the rear rose joint down a bit? I have started posting on Instagram also my name on there is turbomk1golf
![]() 105 Posts Member #: 9378 Advanced Member Chobham |
26th Jul, 2013 at 08:09:29pm
Have you put the UJ's opposite by 90 degrees? The cyclic variation of a UJ increases with the angle it's placed at, but by using two 90 degrees apart this variation is effectively cancelled out |
26th Jul, 2013 at 09:26:58pm
Simon, I have lowered that rear joint and although it has reduced the angle its no better and also faces the steering wheel at the sky. lol
26th Jul, 2013 at 10:00:12pm
Is it the pic or are the joints not inline.? I run a supercharger and I don't care the TB is on the wrong side.
27th Jul, 2013 at 05:44:12am
Nice foot rest On 11th Feb, 2015 robert said:
27th Jul, 2013 at 09:00:27am
How about fitting a bracket between the two rod end mountings bosses with a third boss in it so you can move that forward most rod end further into the cab enabling you to move the UJ aswell reducing the angle. Ofcourse you will need to play with the lengths of the column sections Edited by paul wiginton on 27th Jul, 2013. I seriously doubt it! |
27th Jul, 2013 at 12:11:38pm
I agree with Paul. I am seeing too much (unsupported) shaft between the steering wheel and rearmost rose joint, so fix by moving both roses back, and then you'll have more room to optimize the uj's
27th Jul, 2013 at 12:38:21pm
Gents , are we saying move both roses towards me to drop the angle of the top uj.
27th Jul, 2013 at 03:52:01pm
Yes. Right now you can clearly move both roses towards the steering wheel (you should have the rearmost one as close to the wheel as possible regardless just because cantilever shafts are bad practice). This might allow this to work (by twisting the rack down) but i still think you'll need to play with the rack if you want to keep the near horizontal column On 17th Nov, 2014 Tom Fenton said:
27th Jul, 2013 at 03:56:17pm
Also, do you have a uj at the rack? I can't tell from the pic. This is essential, otherwise that (near vertical) shaft will be very difficult to set up. On 17th Nov, 2014 Tom Fenton said:
27th Jul, 2013 at 06:28:28pm
Dave, yes there is a uj at the rack.
27th Jul, 2013 at 06:30:34pm
At least you have found something mate, it would be a shame if you had to start cutting the frame about.
28th Jul, 2013 at 08:19:16am
Definitly tom. the hope now is that when the rack is sorted the uj's will be less of a problem and can live with it
