Home > 998cc > Well this is Odd.
Chalkie
Member #: 9764
Northamptonshire.
Right guys I asked ages and ages ago about my 998 block fine to over bore
well I have finally got pictures of the underside of my block meet my pain in the ass (not the misses)
Cylinders 1 + 2 (furthest from rad end)
Cylinders 3 + 4 (Nearest Rad end)
Believe it was Will.H who said about blocks being sleeved and not from factory
is this safe to over bore or is it scrap it buy a new block?
Thanks
Stephen
Sleeved blocks can usually be bored .20. What's the OD of the sleeves?
Fit .80 pistons from Minispares?
That's a new one on me!!
But those sleeves are not factory. All the factory sleeved blocks I have seen have a different casting to that.
You'll need +20 to get decent pistons, and that should be fine.
Chalkie
Member #: 9764
Northamptonshire.
I wanted to go around 1060cc ish haha
I thought it was an odd bod but its standard bore size
thought it was odd it was painted red inside not a hit of black or yellow paint anywhere...
It's probably been reconditioned in the past.
Personally I would start with another block. If they only bothered to sleeve two bores, who knows what else they didn't do right...
Chalkie
Member #: 9764
Northamptonshire.
Pistons where fitted backwards aswell haha
998 blocks are cheap and easy to get hold of, I'd just get another.
Chalkie
Member #: 9764
Northamptonshire.
Ive got a 998 A plus block in the shed
Ill turn this one into a table then.
Chalkie
Member #: 9764
Northamptonshire.
But would perfure a A series 998 though
John has two 998 A blocks for sale.
jlay
Member #: 1742
essex
Why do you want a series? I may have a block from a standard bore 1098 its had water sat in it so will need a rebore but if your going large should be fine.
My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901
Chalkie
Member #: 9764
Northamptonshire.
A series main bearings are better IIRC
where the A plus dose not
you can just file either bolock to take either
Chalkie
Member #: 9764
Northamptonshire.
Wouldn't like to file it personal :(
I think it was Veg who was arguing this?
Is the differance that the A+ ones have a solid lower bearing and the A has the groove?
I prefer the solid and have never had a problem.
Chalkie
Member #: 9764
Northamptonshire.
Not sure dude but I perfure the groove :) but then again you are the master of small bores haha
Chalkie
Member #: 9764
Northamptonshire.
Dose this bottom end look standard to you guys? out my A plus engine
The few A series engines I had to bits before only had 6 sided nuts and the crank didn't look as machined as this one
any thoughts thanks
Spank
Member #: 909
yep, that's stock. Someone else may be able to tell you when the rod bolts were switched, but all of the A+ units I've opened had the 12point rod bolts.
Chalkie
Member #: 9764
Northamptonshire.
Thats what I thought
A series had 6 piont and only times Ive seen 12 point was in ARP rod bolts hmm but thanks dude its cleaner than my a series
