| Home > Help Needed / General Tech Chat > Cylinder head blanking | |||||||
90 Posts Member #: 10229 Advanced Member Stroud |
27th Jul, 2013 at 05:43:23pm
Is there any advantage to having the heater tap take off on the cylinder head blanked or not blanked and used to drain into the bottom hose? I have no heater so no need for it really, unless its advisable to let water pass through it? |
27th Jul, 2013 at 05:48:54pm
Some people say to do it, but in my mind it allows water to bypass the radiator. Personally I have blanked it. On 11th Feb, 2015 robert said:
27th Jul, 2013 at 06:52:13pm
You need to drain it into the top hose unless you route it through a heater matrix First. I'd do it. On 13th Jul, 2012 Ben H said:
27th Jul, 2013 at 08:51:57pm
Top hose? Surely it would need to drain into the bottom hose? I.e connecting where the other heater pipe would go? Therefore creating that circuit minus the heater? |
27th Jul, 2013 at 10:15:44pm
No. On 13th Jul, 2012 Ben H said:
27th Jul, 2013 at 10:19:14pm
Agree with Vegard, route it back to the top hose to stop hotspots around no4 I seriously doubt it! |
28th Jul, 2013 at 07:16:45am
Ok sounds good, thanks guys. I currently have fittes the later metro thermostat housing with the outlet on the side, can i use this to attached the pipe from the heater side? |
282 Posts Member #: 1404 Senior Member The Netherlands |
28th Jul, 2013 at 07:26:53am
On 28th Jul, 2013 Chris-G said:
Ok sounds good, thanks guys. I currently have fittes the later metro thermostat housing with the outlet on the side, can i use this to attached the pipe from the heater side? This should be fine
there is nothing wrong with a A-series that a turbo can't fix.
28th Jul, 2013 at 09:26:26am
I've used this.
28th Jul, 2013 at 01:23:58pm
I have the thermostat housing without the sandwich plate. This has a 8/10mm outlet to go to the header tank (if fitted). Can this be used instead? |
28th Jul, 2013 at 05:48:50pm
I do believe the pipe should be routed back into the bottom hose and here is why. The metro uses a sandwich plate which allows the water pump to pump water through the block up through the head to the underside of the thermostat out through the sandwich plate to the heater matrix and inlet manifold if memory serves creating a bypass and continual water flow around the block and head until the thermostat opening temp is reached and the radiator is brought into the circuit.
Own the day
28th Jul, 2013 at 06:42:10pm
Ok, really confused now. To confirm; i am not using the metro thermostat sandwich plate, i can use either the metro or standard mini thermo housing as i have both in my spares box! I have no heater matrix fitted. I am using the minispares late type 'no bypass' water pump. I have a 74 degree stat with a few small holes drilled in it.
28th Jul, 2013 at 09:06:31pm
You have the holes drilled in the thermostat plate to let the water circulate so there should be no problem. Own the day
28th Jul, 2013 at 10:09:45pm
Thanks but im still unclear if that means, blank it? Or run the heater outlet to the bottom hose? Sorry to keep repeating! |
224 Posts Member #: 9987 Senior Member Amsterdam |
29th Jul, 2013 at 08:33:06am
Some have already given you the right pointers, but I can understand why you're confused with others stating the exact opposite....
29th Jul, 2013 at 11:42:37am
Thanks for clearing that up evoderby. I will make a connection to my thermostat housing and connect the heater tap oulet to this. Thanks. |
![]() 270 Posts Member #: 69 Senior Member Coventry |
2nd Aug, 2013 at 01:08:41am
EVODerby exactly right..... |
