Home > Wanted > flange
t3gav
Member #: 229
Gavin@minispares.com
kent
i'm after some late mini 8.4" drive flanges as this is what kad told me to get! bit confused though the flange doesnt have the mounting holes for the caliper or does it? i've never had to take my hubs apart yet is it easy? please pm me if you have some thanks, gav
flange doesnt have anything to do with the calliper, its the bit that has the wheel studs in it *smiley*
easy enough to take off, you'll have to take the driveshaft nut off mind and thats tight, a windy gun works best!
Not that expensive new from minispares IIRC.
Take the hub nut off as Iain says, then undo the 4 9/16" headed bolts that hold the drive flange to the disc, then give the disc a tap with a hammer and you have got the drive flanges off.
t3gav
Member #: 229
kent
hmm why do i have to change them then kad said the metro ones are harder to fit i had metro 4 pots that doesnt mean i had metro flanges though does it as i was using mini wheels.
yep, metro 4 pots have a different flange to account for the vented discs *smiley* you use these on the mini when using the vented metro 4 pots.
obviously kad's are based around the std mini drive flange which is different.
t3gav
Member #: 229
kent
just gave them a ring their flanges are made specifically for their callipers, solves that then! bit confusing as mini spares sell 2 different late mini flanges vented and non even though late minis didnt have vented discs, theses are designed for minispares own callipers in case anyone was wondering!
i love the word flange
t3gav
Member #: 229
kent
was waiting for that from someone lol!
