Home > For Sale > Metro Turbo Engine
kappa
Member #: 9854
Hounslow, Middlesex
Hi all,
I have a complete metro turbo engine for sale
Basically the spec is:
1.5 roller tip rockers
Modified head with chambers opened up to 26cc
New head gasket
New clutch plate and pressure plate
4 Pin Diff
Straight cut drop gears by Swiftune
Mirage manifold
Hybrid GT15/T2 turbo with 360 degrees thrust bearing
Turbo manifold
Turbo carb
Turbo Plenum with side pipe welded on for dumpvalve
The engine did not need any work on the pistons or crank as was all in good condition.
New big end's and small end's
New conrod and head bolts
New oil pump
The engine has never been ran, since I done all the work, but has alot of pressure and turns by hand. I changed my mind it what I was doing with it, as now I am going Suzuki
I am looking for £1300 for the complete unit and I am based in Hounslow, Middlesex, london.
Bobby
Will upload pics later tonight
kappa
Member #: 9854
Hounslow, Middlesex
t@z
Member #: 452
Chester, UK
Bobby might be worth stating pistons, bore, gearbox is it std? Etc
History the block, mileage/new?
1300 seems a bit steep but I'm a tight ass lol
Gl
www.twitter.com/lilpinkiy
kappa
Member #: 9854
Hounslow, Middlesex
Cheers T@Z, sorry should of mentioned that, its a 1275cc, bores were in good condition, gearbox is standard, with central oil pic up pipe and 1:1 straight cut drop gears.
Not sure what the milage is of the engine though
kappa
Member #: 9854
Hounslow, Middlesex
bump
kappa
Member #: 9854
Hounslow, Middlesex
bump
If you was to split i would be up for the Mirage manifold if he price is right.
Simon.
kappa
Member #: 9854
Hounslow, Middlesex
Want to really sell it as one whole unit, but if i decide to split will let you know mate
kappa
Member #: 9854
Hounslow, Middlesex
bump
ALLEN
Member #: 10530
Hi kappa
I'm interested in the motor. Im based in South Africa which means the landed cost would be aprox £1000, based on this , I'd like to make an offer of £700
dev 11
Member #: 9393
stoke on trent
Pisser 700.
ALLEN
Member #: 10530
Forgot to mention I already have a turbo so I don't need that one
WRLondon
Member #: 8636
Surrey
On 5th Aug, 2013 dev 11 said:
Pisser 700.
Lol
main thing is, does it run?
also its a verto clutch set-up so probably not a metro turbo (cant see the numbers)
have you got any pics of the crank & head when you changed the bearings & studs?
what size where the journals?
defo worth more in bits though
Reading up on RTS Clutches
metroturbo
Member #: 989
North Yorkshire
All metro turbos used the verto clutch, and early ones had hydraulic.
kappa
Member #: 9854
Hounslow, Middlesex
Allen sorry I will not let it go for £700, WRLondon yes its a verto clutch, sorry I should of taken pics of the build process, but I did not, so have no pics of the crank and head
ALLEN
Member #: 10530
Ok, so what price would you be willing to let it go for?
kappa
Member #: 9854
Hounslow, Middlesex
£1200 is the lowest I will go
ALLEN
Member #: 10530
Im sorry, but the most I'm willing to go is around £900.
kappa
Member #: 9854
Hounslow, Middlesex
provisionally sold
PM me if it doesn't sell please.
kappa
Member #: 9854
Hounslow, Middlesex
SOLD
