Home > Show Us Yours! > Benefits of a side mount?
minimongrel
Member #: 10419
I know that side mounts look better but besides that im not sure how many benefits there are. Actually are there and Disadvantages too?
Disadvantages:
-worse weight distribution
-more complicated manifold and probably more expensive
-heavier manifold
-Not efficient use of engine space
Advantages
-potentially a better manifold design, but no actual definitive proof
-Potentially easier oil return
-you can fit a bigger turbo (But the biggest that is sensible will still fit behind the block)
-better heat distribution, i.e. won't heat your carb up.
It looks good?
Going on Wintersurfers experience. It's probably worth a good few extra hp.
His car makes over 150 bananas on 10psi.
afrance2905
Member #: 10512
whitby, north yorkshire
the project 64 mini that set the fastest under 1 litre car was a side mount bmw k head mini
