Home > Help Needed / General Tech Chat > Can't find a suitable fuel filter.. So I'll make my own?
Custard
Member #: 8215
Rayleigh
Hello, I am sick to death of searching the World Wide Web for a fuel filter with a 13mm Id on the in and outlets.
I want a large inline filter to pre filter my pump. The outlet on my tank is 13mm Id 16mm od
So the fuel line is 16mm bore.
Thus I need a fuel filter suitable for aforementioned hose.
Does anyone have any knowledge on making a fuel filter, I assume the mesh type ...
As I am planning on laser cutting a series of discs all with lots of little holes in. Then welding them into a tube before completely welding the filter up.
Basically I want to know the size of holes/ total area of a 150? Micron filter would pass.
Ttfn
Dave the Cake
Custard
Member #: 8215
Rayleigh
I'd like to add I'll perform a few tests before actually using it!
Ie, how much water it passes per min
Filtering dirty fuel etc.
It's for the gravity feed to the fuel pump so under no pressure
Dave the Cake
Search eBay for 'sytec pre pump filter'
or buy an uno turbo filter
-edit there dont seem to be anymore of what i bought
Edited by Brett on 31st Jul, 2013.
steve w
Member #: 1917
AKA chargedzetec
As above, Matt Lewis Motorsport do a sytec prefilter with interchangeable ends. I have one fitted.
Mine has changeable ends.
You can specify the size on the Sytec ones sold on eBay.
Custard
Member #: 8215
Rayleigh
Excellent thanks guys, I recon 15mm push on will be ok for a 16mm bore hose
Dave the Cake
