| Home > Help Needed / General Tech Chat > O/T Car Air Con | |||||||
1st Aug, 2013 at 04:31:52pm
Driving home from t'mill earlier. Had what looked like smoke coming out of the central air vents. Once I had unclenched, I had a feel. Very cool to the 'touch', no odour and the metal bits on the vents where ice cold. Temperature outside was about 31, in the car about 22 degrees. A quick under bonnet check reveals I'm not on fire. Had a quick google and turned up this:
1st Aug, 2013 at 04:36:11pm
Yes! as per the email I've just sent you.
1st Aug, 2013 at 04:44:55pm
Its a hot and humid day today, your air con is obviously working well enough to condense some of the moisture in the air to water vapour which is what you are seeing. Don't worry about it, if anything it just means your air con is working well so bonus!
1st Aug, 2013 at 04:51:04pm
Smashing. Thanks for the reinsurance. My second or third thought was 'ooooh. new car time On 11th Feb, 2015 robert said:
