| Home > Wanted > Wanted: 8mm Turbo Valve Retainers | |||||||
265 Posts Member #: 368 Senior Member Roseville, CA (USA) |
11th Jul, 2005 at 07:30:01pm
My moronic ex-machinist managed to lose my exhaust springs and bits. I disassembled another head and got the springs and retainers from that, but when I got the head together, my exhaust springs were too low. I believe that there is a difference to the taper and/or diameter of the inner portion of the retainers due to the fact that the exhaust valves are 8mm, versus 9/32". Does anyone have four retainers in a coffee can that they're not in need of anymore? **************************************
12th Jul, 2005 at 07:37:29am
can get them from minispares if you get stuck.
12th Jul, 2005 at 09:06:48pm
Thanks, Iain. Do you know the part number, or name MS might use? I've tried every combination of words in the search engine, and come up with a minimum of 26 pages of product to slog through... **************************************
12th Jul, 2005 at 09:26:26pm
http://www.minispares.com/Product.aspx?pid=32930
12th Jul, 2005 at 10:36:45pm
Iain, you're a saint! I have the most rotten luck with using the search engines on both MiniSpares and MiniMania...
13th Jul, 2005 at 07:45:03am
No worries |
