| Home > Help Needed / General Tech Chat > reconditioned gearbox crunching on 3rd | |||||||
69 Posts Member #: 10545 Advanced Member MAURITIUS |
7th Aug, 2013 at 01:04:50pm
7th Aug, 2013 at 01:11:14pm
Don't know if it can help,
7th Aug, 2013 at 01:13:13pm
Definately check your clutch isn't dragging but it sounds very much like you have a syncro issue.
7th Aug, 2013 at 01:17:45pm
Thanks for your reply,
7th Aug, 2013 at 01:26:44pm
Probably, more so in lower gears too I would have thought. If something is worth doing, it's worth doing half of. |
7th Aug, 2013 at 01:30:19pm
On 7th Aug, 2013 minimauritius said:
I'm thinking of a defect baulk (there from minisport) There's your problem. On 11th Feb, 2015 robert said:
7th Aug, 2013 at 01:31:26pm
Ok, sounds like engine will have to go out again... third time in two weeks... good practice |
7th Aug, 2013 at 01:39:01pm
bearings are from them too, hope they will last longer than 20 miles!!
7th Aug, 2013 at 02:04:22pm
Personally I've not had much luck with minisport. Quite a few on hear have had issues with parts not being as described. On 11th Feb, 2015 robert said:
7th Aug, 2013 at 02:09:12pm
Yep, they sell stuff using gen part numbers when they aren't! If something is worth doing, it's worth doing half of. |
7th Aug, 2013 at 02:27:13pm
In fact idler bearings were missing from the gearbox bearing kit that I bought |
7th Aug, 2013 at 02:32:34pm
Do you think learning double clutching would help me in my case ? I've just tried the car again and third only crunch over 3000rpm |
7th Aug, 2013 at 02:42:41pm
You said double clutching didn't help. I would pull it out and pull it to bits. On 11th Feb, 2015 robert said:
7th Aug, 2013 at 02:48:56pm
hum...think I'll have to wait a little before pulling out again (money,wife...). I'll continue the running in and will do it when I regain energy and motivation... |
7th Aug, 2013 at 02:53:24pm
I know that feeling On 11th Feb, 2015 robert said:
7th Aug, 2013 at 04:05:36pm
The baulk ring could be stuck on the come of the gear I've had this problem in the past! |
7th Aug, 2013 at 05:36:06pm
thank you Star Mag,
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
7th Aug, 2013 at 09:12:05pm
Felt the need to post you this, you may interested in reading before you do the gearbox again, I don't know who it was but someone put a link to this on another thread on this forum, and I copied it for future reference. Alan
Main Build
![]() 553 Posts Member #: 1356 Post Whore TRURO, CORNWALL |
7th Aug, 2013 at 09:20:39pm
Oh shit? My new box has genuine rover baulk rings in it. Thought they were the best of a crap bunch |
7th Aug, 2013 at 10:06:18pm
![]() From my recollection, there were only two types of baulk rings, bronze and steel. At some point early on Austin Rover stopped making the bronze rings (brown in colour) and replaced them with the steel rings. The fact that the Aus guys are complaining about the sintered steel, is funny because the bronze rings are also sintered and a softer material. Infact the bronze has a lubricating property of its own used in an application that require a level of friction to 'grab' the gear and speed it up or slow it down. One other thing to consider here is that the Aus bunch are predominantly using PRE A+ gearboxes which originally used the bronze rings, perhapse the gear cones had a different coating that wears the steel rings faster since bronze has a lubricating property, the part it bears on may need to be 'more grippy'? I'm not sure. To be honest, looking at the two pictures, I'd have said the top pic was of a worn ring, and the bottom ring was what a new ring should look like, but this chap seems to think the opposite. all the new rings I have ever fitted have had the sharp serated edge to them and never posed a problem. All I have ever pulled out of factory built A+ gearboxes are the steel rings, and I have in the last few weeks actually dismantled one from 1983. If these steel rings were such a problem, I'm sure there would have been far greater issues Austin Rover would have to have delt with over the years with Warranty returns regarding these suspect rings. It just never happened so the problem was never there. That is not to say that the parts you buy now are just as good, infact I think it is the complete opposite. I completely distrust anything with an MG Rover sticker or box. Knowing there has been some issue with baulk rings in the past, I have kept every single ring I have removed from every box I have dismantled for future use, enough to be selective for gearbox builds of my own. As for a sticking baulk ring causing crunching, I doubt it since that is the whole purpose of the ring, to stop the gear and allow the synchro sleeve to slide over the dog teeth without crunching. If it is stuck to the gear, both the gear and the synchro sleeve must be turning at the same speed ergo no crunch. Also, like anything in MG rover packaging, anything from Minisport is eaqually as suspect, but I'd be much happier with the MG Rover stuff than the Minisport stuff, but thats just my opinion. When all that is said and done, I have used the Minispares baulk rings in several gearboxes I have built and none have ever complained on their function to date. So, I can only recommend two things. Only ever use good used genuine baulk rings, or new Minispares steel Baulk rings. Edited by Sprocket on 7th Aug, 2013. On 26th Oct, 2004 TurboDave16v said:
7th Aug, 2013 at 10:18:37pm
Which clearence was it between the synchro ring and hub? My experience is that 1mm is minimum. On 13th Jul, 2012 Ben H said:
8th Aug, 2013 at 08:05:21am
I didn't check this clearance as everything was good in the gearbox before the rebuild.
8th Aug, 2013 at 08:55:08am
I too have experienced a new baulk ring sticking to the cone (can't remember which make but I now too use good old ones).
8th Aug, 2013 at 09:08:48am
Interesting...
8th Aug, 2013 at 09:18:05am
Going into neutral would move the synchro hub back, but if the baulk ring is still stuck on a cone it wouldn't pull it back with it as they are floating between the gear and hub. On 11th Feb, 2015 robert said:
