Home > Help Needed / General Tech Chat > How to find a Nice Box
Well as I am starting again and my gearbox is in need of a rebuild I have been looking at what I have sat about.
So how can I tell if I have a good case or not? as I would like a good starting point.
Simon.
The lightest one in your stash with all good threads - obviously only 3 bolt holes in the centre web and one that doesnt have horrible casting across the top of the centre web too. Check the input bearing hole is not worn
That's it mate, most of the threads are fucked in my box at the min.
And if you remember me saying at Avon I was not sure what it was well it turns out that its a Jack Knight Box lol. so I think I will look after it lol. So I think its rebuild time.
Make sure you grind off all of the casting marks too, as that'll help relieve any high stress areas. You only reasilse how bad they are, when you start to try and remove them! Lol
There is more to this then I was think then.
Ok I have found one that looks the best from my stash, so am I just cleaning it up where I marked?
Thats the idea, but once I started I couldnt stop and went nuts on mine
You can only see a bit of it here
WRLondon
Member #: 8636
Surrey
thought that splash guard was the casing for a sec haha!
looks great as usual paul
Reading up on RTS Clutches
Well I have been pissing about with it, am I going right down so the centre web is flush both sides? as there is a lot of meat to come off it then lol.
Also is the out side fair game? or should I look out for any thing?
Just anything that is not smooth really mate. If it has a rough edge it can crack
Chalkie
Member #: 9764
Northamptonshire.
How come it cracks from a rough edge? just wondering
WRLondon
Member #: 8636
Surrey
from the casting, basically two bits of metal pressed together
as appose to forging which is a single complete piece
Chalkie
Member #: 9764
Northamptonshire.
oh okay but surely it could still crack there?
Chalkie, a good analagy is - when you polish your car and have a roll of mutton cloth it is difficult to tear a bit off but if you put a small cut in it you can tear it easier, its the same with a casting - if it has a rough edge it can crack from there but if you smooth it off there is nowhere for a crack to start
Chalkie
Member #: 9764
Northamptonshire.
Right okay thanks I get what you mean now.
thanks
afrance2905
Member #: 10512
whitby, north yorkshire
with a smooth edge you spread the stresses in lots of other places making it harder to crack instead of in one perticular place if it is sharp
Chalkie
Member #: 9764
Northamptonshire.
These are both my boxes gonna rebuild one but witch case is best?
850 one
998 one
thanks
What are the casting numbers?
They both look like 4 bolt retainer boxes, so neither is great for performance builds.
Hard to tell with all that shite in there. Strip them and clean them. Then give us new pics
