Home > General Chat > Center main strap for 1.75"
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
anyone know if an aftermarket probably steel? one is made to fit small bores 1098cc
im looking for an alternative to the separate chunk of steel siting on top of a shaved down factory cap
i had a look today with the idea of fitting a girdle to the main caps but it became clear that is not an option due to space once i had an block and box sitting together with crank rods and pistons
http://www.pavtek.com.au/index.php?option=...d=102&Itemid=33
edit link to v8 type
Edited by Turbo This.. on 21st Aug, 2013.
Chalkie
Member #: 9764
Northamptonshire.
Minispares do a 998 one I believe and sure Minisport do too
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
chalkie could you link to the item you are meaning? cant seem to fint one im after this sort of arrangement rather than a separate item fitted on top
http://www.swiftune.com/Product/1003/swift...r-s-4-bolt.aspx
Chalkie
Member #: 9764
Northamptonshire.
Oh you wanta 4 bolt setup
just email them sure they do one tbh
but i have heard it removes some strenth from the block hmm
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
at what RPM and or lb·ft would you be concerned that something needs to be done to strengthen the main cap or caps?
I'm not sure a 1098 crank will be up to the kind of rpm to justify a 4 bolt strap.
I would just centre strap it.
IMO a centre main strap will be ok .... but if you have the time and dosh for go the full treatment
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
benross, at this point im a bit fed up with trying to find longer bolts for the additional strap thickness
im not happy with 10 odd mm of stud in the block and ive been told its a 3-4 week wait for arp studs
i cant find a 1" 3/4 steel main cap for small bores so i think ill just leave its STD
after all the cam runs out of legs at 6k and with the 83mm stroke i plan to keep it under 6.5k or what ever is max ft pounds
im looking to make loads of torque to pull the sccr box and 2.95 diff its a heavy std weight clubman
i was looking at strengthening the main cap/s to help with the load and reliability so on but i think if i treat it nice and have things set up right ill be ok?
ive lernt my lesson on being rough trashed the drive line cvs inner and outer trashed the main bearing (broke the cage) chewed the syrncrows up and the slider hubs the lot crank also cracked 3/4 the way around shop said your a lucky man this is not in two
Fast carl can get you some suitable bolts...
Chalkie
Member #: 9764
Northamptonshire.
Get some nice Hardened washers too
Keith Calver cover it a while back, saying the bolts chew there way into the washers but use a hardened one it stops it doing that
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
thanks guys but im going to just go with factory caps and ARP studs/bolts/washers
perhaps i was being to paranoid (like normal) about flex/lack of strength in the crank/main line
i think it will be ok keeping to my 6.5krpm limit and having my rotating assembly lightened and balanced should be ok
