Home > General Chat > Aluminum Roll cage
minimongrel
Member #: 10419
Hey Does anyone make/use a aluminum roll cage, I want some safety componants but dont want to sacrifice that much weight, any iders?
Clive1330
Member #: 10230
I'm sure all the alloy cages I've ever seen are just for show but I could be wrong
To make an Aluminium cage strong enough, it's have the to huge (as in massive diameter tubes).
The compromise would be just a rear cage, rather than a full one.
vegar
Member #: 189
Installing a insufficient cage are dangerous. A rollcage is not that much waight enyway.
www.shag.no
minimongrel
Member #: 10419
alright then mooped point.
AWDmoke
Member #: 713
Western Australia
FIA banned aluminium roll cages years ago, unless the car was already log booked with it - like my mini!
A stronger cage can be made just as light from chrome moly steel.
On 24th Dec, 2008 Nic said:
Someone posted this info up for me on that other mini place on the net *wink*
Here's some weights of my Safety Devices 6 point bolt-in cage etc.
Roll Cage Rear with diagonal (not including nuts, bolts or plates) = 15 kg
Roll Cage Inner Floor Plates Main Hoop Pair = 0.646 kg
Roll Cage Outer Floor Plates Main Hoop Pair = 0.377 kg
Roll Cage Main Hoop Nuts, Bolts & Washers x 10 = 0.380 kg
Roll Cage Inner Floor Plates Rear Legs Pair = 0.697 kg
Roll Cage Outer Floor Plates Rear Legs Pair = 0.268 kg
Rear Roll Cage Legs Nuts, Bolts & Washers x 6 = 0.228 kg
Front Roll Cage Includes Nuts, Bolts & Washers (not floor bolts or plates) = 9.502 kg
Roll Cage Inner Floor Plates Front Legs Pair = 0.895 kg
Roll Cage Outer Floor Plates Front Legs Pair = 0.275 kg
Roll Cage Front Legs Nuts, Bolts & Washers x 6 = 0.228 kg
Roll Cage Door Bars Pair (Including all Brackets, Nuts, Bolts & Washers) = 5.0 kg
