Home > General Chat > is the rear lower valance structural?
JetBLICK
Member #: 1261
Droitwich
I know you can get fiberglass ones, but im using a std subframe. In the opinion of the people on here, is the rear valance, and closing panels, providing any support to the rear subframe?
afrance2905
Member #: 10512
whitby, north yorkshire
seen alot of people not using them and mini miglias dont use them, i wouldnt of thoughts so but for mot perposes i dont think it would pass unless you use a rear beam, all though most mot guys i no miss things alot worse than no rear valance
If its fitted it must be in good condition for the MOT as its within the specified area of a major mounting point but if its not there it wont fail the MOT - it is not structural
afrance2905
Member #: 10512
cheers paul, i was wondering about this aswell
JetBLICK
Member #: 1261
Droitwich
Most helpful, thanks :)
Yes 100% what paul says, mine failed the mot for this being rotten some 5/6 years ago
Its not had one since and never had a problem
Chalkie
Member #: 9764
Northamptonshire.
Make sure there's no sharp edges about though as thats a MOT fail.
Rammie2000
Member #: 10190
belgium
Mini is fibreglass its on there for 7 years now. No problem what so ever.
JetBLICK
Member #: 1261
Droitwich
Cool beanz, I was less worried about MOT regs, it was more about the chassis stiffness. Good to know, that'll come off next then.. lol
afrance2905
Member #: 10512
i wonder how much it weights? with the plates included
dev 11
Member #: 9393
stoke on trent
just make sure when you cut it off, the boot floor and the hinge panel are connected, when i cut mine off i had to weld the floor to the hinge panel.
Rammie2000
Member #: 10190
belgium
I left the lip on and cut it of just underneath so al the welding remaind together. Actually its only stuck on there with silicone and the bumper bolts...
Rammie2000
Member #: 10190
belgium
