| Home > Technical Chat > 7 port head | |||||||
4 Posts Member #: 608 Junior Member australia |
15th Jul, 2005 at 11:09:01am
Hello all, from down under. Have recently been bitten by the mini bug as a friend of mine wanted to make his old mini 1100 go faster than its normal snail pace. I know nothing about A series engines & have enjoyed reading various articles in this informative forum. Have come from a turbo rotary background & offered to apply my knowledge to his long term project. The first stumbling block I noticed was the poxy Siamese inlet ports! Have enlarge these to the point where I entered the push rod hole area & have had some sleeves pressed in with the minimum possible id. to allow as large as possible port. Then made a divider plate so I will end up with 4 X "D" shaped inlet tracks. All be it not enough flow for a normally aspirated hi hp. application, add a turbo & let the flow begin! I now have 4 separate inlet ports, will use 4 injectors & can easily & efficiently control fuel delivery using any number of aftermarket efi systems. We are using the 1100 because it's what we have got .If any body is interested I will post progress reports & pics as we go. Regards Russell |
15th Jul, 2005 at 11:13:02am
get some pics up |
15th Jul, 2005 at 11:43:19am
iain, will be 3-4 weeks before the head will be photogenic (as this is is a part time project) & hopefully the inlet manifold will have progressed enough for pic's by that time as well. |
15th Jul, 2005 at 12:10:06pm
sounds cool,
15th Jul, 2005 at 12:42:58pm
I have considered doing the same thing. On a 998 or 1100 turbo I reckon you can get the ports big enough this way. Not sure if they would be large enough on a 1275+ though. I will be interested to see how it looks, I am still at the planning stage.
http://www.twin-turbo.co.uk
15th Jul, 2005 at 01:23:33pm
good good, i look forward to seeing the pictures
15th Jul, 2005 at 01:47:00pm
Which was owned by Bank Garages. The owner of BG is a complete tosser and lies about everything...
15th Jul, 2005 at 02:48:00pm
yeah i reckon the MG range are now fantastic value for money.
15th Jul, 2005 at 03:00:05pm
Hmm, Its a damn shame that there's so many tosser's out there that talk complete BS, I bumped into a guy in my local recently who was asking about my min...
15th Jul, 2005 at 11:40:43pm
On 15/07/2005 13:47:00 Vegard said:
Which was owned by Bank Garages. The owner of BG is a complete tosser and lies about everything... it was owned by some one called dave belcher then, which is prior to wank garages owning it, i believe |
16th Jul, 2005 at 08:40:16am
mini 13 There are as you call them "tossers" out there. In Aus we call them "wankers" I can assure you this head is happening & as I stated I know nothing about A series engines but feel sure with my 38 yrs experence as a mechanic ( yes I'm old ) & the last 20 yrs in the modified car scene, I can make this old mini fly.I've been actively envolved in the turbo rotary industry for the last 12yrs. & thought I could apply my turbo knowledge to my mates mini. If the head works I'm more than happy to post my findings as the mini scene in Aus is very small & not many are interested in my ideas. be patiant the pic's will come. Russdog |
16th Jul, 2005 at 10:53:01am
russdog
16th Jul, 2005 at 12:04:03pm
Ben, it isn't a brand new casting design. The head has been sold in Denmark for over 20 years.
Edited by Vegard on 16th Jul, 2005. On 13th Jul, 2012 Ben H said:
16th Jul, 2005 at 06:21:05pm
intresting link vegard,
18th Jul, 2005 at 11:20:03am
Russdog, my anecdote on tossers was in no way meant to be derrogetory to you, On the contary any one that works on rotary engines has my respect (I still consider them witchcraft)
146 Posts Member #: 350 Turboing minis since '89<br> Supercharging minis since '04 |
18th Jul, 2005 at 09:13:03pm
i called mine the 'split port ' it was a flow bench test 'mock up' with alloy plate epoxied in place 9/16 in offset pushrod tubes , using a 36 mm inlet airspeed was around 3.5 times higher velocity, but just couldn't get enough flow to make it atmo usable - as i recollect 69 cfm @10in h2o on a superflow 110 with 1/2 lift (standard 36 mm head flows 63 cfm, race 36 head 93cfm both at 500 thou VL, conclusion was it would make a good atmo engine for towing ! but with forced induction puts a different spin on things , maybe use a more balanced inlet to ex ratio on the cam to make up for reduced flow , ie 276 or 286 ? |
19th Jul, 2005 at 08:06:25am
Stuart, I think this is what you are saying:
19th Jul, 2005 at 08:54:57am
i dont ! , it was a flow bench trial ,still got the program in my mind ! but yes it would work even better with smaller cc's ,the inlet port was large and sqaure untill the divider went in making two rectangular ports, not sure how long epoxy would last , maybe something a bit more nasa spec is available now ? would work perfectly with injection manifold will take some fine fabrication to get get right , mirage mentioned some specialist grp stuff to make inlet manifolds maybe thats the way ? |
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
26th Jul, 2005 at 09:58:19pm
Having a bit of experience with fluid flow (and gases) I reckon from what I've done with heat exchangers the same principles apply. I reckon that the split port idea stinks. Sure you'll get rid of the charge robbing but the resistance of the tube is considerably higher. I think of it like this, image that the walls of the port are sticky (they are to air) the air is also sticky against air and moreso when you pressurise it, so, ideally if you imagine having a section of the port (circular) the gas in the centre will be at a higher speed than that at the edges, obviously this ideal circle distorts if you're trying to make it turn corners (imagine bending a piece of pipe lagging). So, the further you distort the shape from the ideal circle, the more the resistance goes up. If you ask me those split ports look pretty antisocial to gas flow. Particularly for a big engine running a lot of gas. As you guys keep telling me, theory is one thing and practice is what counts, I would be very surprised if the flow on a flowmeter was not a lot less. Who knows whether the benefits would beat the limitations.......I doubt it. I reckon that downdraft 5 port looked like a good idea.
Bugger off, I'm getting there. |
27th Jul, 2005 at 09:49:09am
stu, post the pics of the cores, or email them to me and I'll post them Team www.sheepspeed.com Racing
27th Jul, 2005 at 10:19:22am
Done it. Bugger off, I'm getting there. |
27th Jul, 2005 at 10:22:39am
I'll them posted asap Team www.sheepspeed.com Racing
27th Jul, 2005 at 12:04:10pm
I was looking at a pic of an elder 8 port about 10 mins ago and somthing clicked, as its xooxxoox cnfig as stu puts it, what must the exhaust ports look like!!
27th Jul, 2005 at 01:25:45pm
will post all pics in a bit
27th Jul, 2005 at 04:28:06pm
This one ??
