Home > Help Needed / General Tech Chat > Brakes - Servo to Cooper-S Cylinder conversion
Yo.
I want to ditch the horrid servo on my car and replace it with the older-style Cooper S cylinder.
I presume I need the cylinder (obviously), then a t-peice and a few bits of brake line, and a few 'ends' of brake line?
Anyone know if I need anything else, or even better, know what exact parts I'll need to do the job?
Ta :)
welshdan
Member #: 1111
s wales
i looked into this a few years ago but didn't bother. think you have to change the pedal box to a non servo one.
DILLIGAF
Member #: 9128
As above disk braked non servo pedal box and you'll need a rear brake pressure bias valve.
You dont need to change the whole pedal box - just the brake pedal as the clevis pin hole is bigger, or you can just weld up the hole and drill a new one the right size then all you need is the new cylinder, the shaped plate underneath it which connects to the engine tie bar and the bias valve
Edited by paul wiginton on 2nd Sep, 2013.
You'll also need the spring as the servo one is only for the clutch. Another bit people forget is the bracket for the engine steady, you'll need one if those too
Its much easier to get hold of a pedal box complete though.
Doesn't really sound too bad considering the huge amount of engine bay space you get back.
any idea on the brake pipe and fittings?
t@z
Member #: 452
Chester, UK
i just changed my whole pedal box, got the new plate for under it (i forgot this at first) and tada.
if you log into minispares they have diagrams https://www.minispares.com/catalogues/class...pes.aspx?1~9~78
www.twitter.com/lilpinkiy
