Home > Technical Chat > Torque steer
I had massive torque steer at avon dispite having a fairly low powered car and a slipping clutch
i set the car up just by eye as i never had time to get it aligned, would standard alignment be ok or would diffrent figure be better?
Get rid of the 13" wheels!
do you have an LSD wolfie? getting your corner weights setup will help, but those 13's are not going to help either, you have 13x7 deep dish don't you, if you want to stick ith 13's try the 13x6's there a much smaller offset, and muhc better
andy c
Member #: 613
Class D Massive Regular
glasgow
torque steer rules!
did you drive the car to avon?
guess if it drives well on the road then don't worry about it
Hell, I used 10" with Sportspack arches ages ago:
http://home.online.no/~lyngset/myold77mini...Type=&pExPic=0;
they spectrums? i take it there 7" wide?
Jim i have a totally standard gearbox inc diff lol im surpreised it did not break
I'd agree with Jim, the wide offset wheels on your car looked great yesterday but can't have been helping the torque steer situation!
giallofly
Member #: 164
The Stig..
Newport Pagnell
look at the suspension set up, then if that fails try fitting some mutro steering arms, they are longer and make the steering lighter but you loose alot of lock....
Shouldn't this thread be called Curly Wurly Steer?
minimark
Member #: 19
newcastle
carl should be able able to sort you out some basic settings to get you going .. sorted BIR1 for me that was on 13`s
I can honestly say that we have never had a problem with torque steer in the TT. That runs on 7x13s.
A bit of toe in and equal camber on both sides and you should be fine.
Wil
lanxter
Member #: 396
sheffield/rotherham
what is the perfect wheel size? ive heard 12's r best 4 a handleing
speed is the best rush i have ever had!!!
add me lanxter@hotmail.com
Different people have different opinions. I personally like 12's, but you can't buy slicks for them (in the right compound) so I went for 13s.
lanxter
Member #: 396
sheffield/rotherham
is it right that you can now buy road legal slicks will?
i like 12's as well my daily driver is on 12's and i can chuck it about all over the place
if i went down to 10's where would i get the wheels? i know spectrums are no longer, not sure where you get MB's from? i know carl does some work on wheels?
jim dont you run 7x10's???
Edited by wolfie on 18th Jul, 2005.
Look at what the fastest cars at Avon park use. Also look at Miglias etc..
10"s are best! :)
Fastes car at Avon. That green thing with 13" wheels.
The slowest car at Avon an 998 on 10s.
Turbo Tim
Member #: 177
Avon Park 2006 Class D Winner
Woburn Sands
Miglias have to run 10s, in thr rules
16V project underway
I have 10x7's yes
jim can you let me know where you got your 10's from?
mine are carl austins mate, forceracing, but his website is down at the moment
or there are MB's, think you can get spectrums still?
err, cant think of many else. Oh yeah saxon rims is it?
Ive got 10 x 6 MB's on mine *smiley*
where do i get mb's iain?
mine came from ML motorsport mate. not sure if its cheaper or dearer to go direct.
mike barnby engineering... they're in the phone book but i cant remember where he's based.
stuart gurr - vmaxscart
Member #: 350
Turboing minis since '89<br> Supercharging minis since '04
is the suspension lifting changing angles ?
i take it all rose jointed ?and theres no play in anything? more castor brings the wheels foward and increses self centering of the steering ,mig set up around 6 deg castor
-- advice from slowest in class d ? @16.5 --
