Home > Help Needed / General Tech Chat > Are these any good
Clive1330
Member #: 10230
After finding out today I need new pistons and block I was wondering if these are any good for a supercharged blow through set up? And if anyone on here is using them?
http://www.minispares.com/product/Classic/...spx%7CBack%20to
I'd say "go for something else".
There have had a fair few failures of the ring lands on moderate boost turbo setups.
Clive1330
Member #: 10230
What do you recommend
Omega cast.
No. No they are not.
They even say this themselves, without any sugar coating at all.
On 6th Sep, 2013 minspares said:
"Sold as a single piston and although for Turbos is from original Rover casting and tooling to run on 5psi turbo boost. They use our mega ringset C-AJJ3379-40
If using more boost you need to be working on a lower CR with a total cylinder volume of 55cc in piston/block/head gasket and cylinder head.
Also when inreasing Boost pressures it is essential to have a modified ignition advance/retard curve to prevent detonation and ensure the Inlet charge temperature does not exceed 40 degrees C by the fittment of a suitable Intercooler.
If our advise is not followed it is very likley you will break the ring lands on your new pistons.
As mentioned - cast omegas are pretty much the best option, and are nigh on indestructable.
Clive1330
Member #: 10230
Ok best get shopping around for the cheapest place to find some then :)
These are used in the Don, been I there 4 years,
no real damage except a bit of det and this a was probably from when either Tom or myself fried the engine on two separate occasions
Clive1330
Member #: 10230
http://www.med-engineering.co.uk/catalogue...istons-die-cast
These ones
Edited by Clive1330 on 7th Sep, 2013.
Clive1330
Member #: 10230
Hi Carl are you using the minispares ones?
Aren't yours an old set though Carl, from when they were considered a very good piston ?
Phil.
Clive1330
Member #: 10230
Think I will go for the omegas there about £310 unless someone knows a way I can get them cheaper :)
I'm going to work on my turbophil head now as it was deamed the only part I had that was usable out of the parts I had to build my engine. Even though its never been put on a car since being built by Phil, the previous owner never stored it properly :(
What did he do, bury it in the garden?
Clive1330
Member #: 10230
Looks like he kept it in his fish tank for safe keeping. No wonder the valves were sealing so well
fuck sake! thats sacrilidge!
try somthing mild like a brillo pad first... you dont want to remove any material and fuck up Phils hard work.
Clive1330
Member #: 10230
Going to soak it in degreaser and wd40 the use a light style wire brush in my dremal and then lap the valves back in
Christ ! What's he done to that ?
I can't believe he let it go like that ? What a mess. If you need any help with anything on it, let me know mate.
Phil.
Clive1330
Member #: 10230
Cheers Phil not what I was expecting after spending so much on it In the first place. Hopefully it will clean up and just needs the valves lapping in
Mr Joshua
Member #: 1954
Luton Bedfordshire
Philip I can only imagine your rage at seeing one of your creations in such a condition.
Own the day
Yes it's pretty annoying when you spend all those hours on it & somebody lets it go like that.
Phil.
Clive1330
Member #: 10230
When cleaning it up yesterday you can really appreciate the time and effort that goes into building a head like this. It looks a lot better now though :)
