Home > General Chat > era mini air filter
era mini mark
Member #: 10523
PALM BAY FLORIDA U S A
hello can someone tell me where I can find a stock replacement air filter for a 1989 era mini ?
I think it uses the same air filter as the turbo metro ...... but I may be wrong? others may correct me
era mini mark
Member #: 10523
not 2 sure about the metro, I believe the metro is under the hood. the era mini is mounted up under the left fender.
era mini mark
Member #: 10523
I c a lot of ppls running the mushroom filter under the hood, but I would like 2 retain the stock era location as its a ram air set up that's fed air through the left front spoiler air duct. so I figure cool fresh air will b much better than hot under hood air.
The filter element for an ERA Mini turbo airbox is an xr3i etc Ford fitment as far as I recall. I know it was not anything special for the Mini, as I was easily able to get a K&N filter for it back 20 years ago.
Just remove the filter and take it to any local motor factors, they're bound to have something that fits.
Edited by stevieturbo on 7th Sep, 2013.
jambo
Member #: 1390
Yeovil, Somerset
I will look out the part number as I had it a few years when I had my era, hope I still have the email ?
James
http://www.fordpartsuk.com/shop/ford_escor...74618_c_322.htm
This listing looks like it uses "Alco" brand, and at least gives you some dimensions.
ie 336mm x 140mm x 40mm
http://www.ebay.co.uk/itm/Air-Filter-Servi...=item4d006ed502
This appears close, but check your own filter dimensions. You can check through for cross reference part numbers and other vehicles it may be fitted to on K&N's website
K&N dont seem to specifically list an RS Turbo or XR3i model. But good chance it's the same as the base 1.6 models.
http://www.knfilters.co.uk/search/product.aspx?Prod=33-2001
http://www.knfilters.co.uk/search/kn_cross...px?part=33-2001
googling some part numbers on US sites
http://www.autopartoo.com/oem/alco-filter/md9400.html
era mini mark
Member #: 10523
thanks a bunch fellas, ill dig a little deeper
smokestack-lightning.
Member #: 10557
http://www.eraturbo.co.uk/technical/page1/i05.png doesnt really help with the number but does give the shape and orientation....
Double-Blind experiment, N:
An experiment in which the Chief Researcher believes he is
Fooling both the subject and the lab assistant. Often accompanied by
a belief in the Tooth Fairy.
Found that site last night myself. Handy to have.
Back in 94 when I built mine, I could just go to my local Rover/Unipart dealer and they had the microfiche there and I was able to order the airbox from them !
Probably not as easy now lol
Ruffles
Member #: 12147
Sandgroper Land, Outer Antipodes, WA
Hiya Folks,
Just resurrecting a very old thread. Following substantial research in attempting to find the correct fitting filter, we found that the K&N part number: 33-2626 filter fits best with sufficient "lip" to be caught between the halves of the case. K&N 33-2001 and others do not have sufficient lip to offer up resistance to afford the clips to clamp properly.
We also found that WIX part number: 42170 is an excellent fit for a disposable paper filter.
Ruffles
If you're in a dusty environment, 100% use an OEM type paper filter. The box has a good size to it and filtration area that it would be of no restriction anyway
