Home > Wanted > NA Metro inlet, fuel pump, fuel hoses etc
jakejakejake1
Member #: 10010
Northants
Hi Guys,
I'm after an NA metro inlet as my turbo inlet fouls on the mirage manifolds in a few places.
Also after a fuel pump, similar to the metro in-line type job, or if anyone could recommend a decent, cheaper one that would be good (i.e. <£40-50).
Also where do people get their fuel hoses from? I'm planning on running 8mm ID flexible hoses the whole length of the car for supply and return (only running a fairly low power 998 turbo).
As well as that can someone recommend some pre and post pump filters to use.
Also does anyone know what type of company i could get to do some surface mount soldering for me to modify my MJ from TPS to MAP, I have all the components just need the soldering done as I'm terrible at soldering.
Jake
Mike-998
Member #: 9774
Buckinghamshire
I used this stuff for my fuel hoses:
http://www.ebay.co.uk/itm/Stainless-Steel-...=item896216c5f8
With some rubber end caps bought from another ebay shop. Happy with the quality of them for the price, and they haven't tarnished at all.
Also got my fuel pump off ebay. Most inline pumps will be fine, mine was off a Porsche, just had to buy a barb tip fitting for the outlet.
Alex
Member #: 1851
Woolavington, Zummerzet
I've got a few MG Metro inlets kicking about - £25 plus postage sound about right ?
