| Home > Technical Chat > Exhaust Stem Seals | |||||||
265 Posts Member #: 368 Senior Member Roseville, CA (USA) |
18th Jul, 2005 at 10:37:08pm
I know that stem seals are not "needed" on the exhaust side of a Turbo (8mm stems), but my mechanic installed them anyway. They're the Viton ones. **************************************
18th Jul, 2005 at 10:52:22pm
the generall thinking of this is.... to do without them ................
18th Jul, 2005 at 11:18:29pm
Thanks, Ben. I'm a little bummed, because I had asked the machinist to install the seals on the intakes on both heads, not all on one. The viton type are not cheap!!! I'll have to buy some more, as they can't be re-used for the intake... **************************************
146 Posts Member #: 350 Turboing minis since '89<br> Supercharging minis since '04 |
19th Jul, 2005 at 08:58:53am
after working with heads for some years, generally seals on ex valves increase guide wear |
19th Jul, 2005 at 09:42:36am
On performance engines(heads) I build I only fit seals on the intakes. On road heads, I fit them on all eight. On 13th Jul, 2012 Ben H said:
263 Posts Member #: 115 Senior Member Austria, near Vienna |
19th Jul, 2005 at 07:17:37pm
I also had a lot more wear on the exhaust valves and guides with seals fitted. Bimmer Twinky headed and turboed A-Series:
19th Jul, 2005 at 08:06:39pm
Generally with the increased heat of the exhaust valve stems, the stem seals quickly go 'hard' around the stem and so don't do much sealing any more. Not sure how these Viton ones you have got will fare.
19th Jul, 2005 at 09:36:19pm
Thanks, guys! Will definitely remove them. I'm just sad that they are most likely now too deformed to do me any good on the intake on the other head...
19th Jul, 2005 at 10:16:44pm
Well seeing as you got your machinst to build the head for you, I assumed you didn't have the kit to do it yourself, hence the hour........
20th Jul, 2005 at 04:59:03am
LOL So, 10 minutes doing the valves, 50 searching for the collets! **************************************
20th Jul, 2005 at 08:06:03am
I know that feeling so so well!!! Alex AlexF |
450 Posts Member #: 449 Senior Member Oxford |
27th Jul, 2005 at 05:40:57pm
I think eveyone that has done a head has done that more than once. However hard you try to keep them under control one manages to escape LOL evem if it only slips out of you fingers when your trying to put them back in!!! |
27th Jul, 2005 at 06:34:55pm
Very true, Mike. I did this the other day. Got all the exhaust seals off. I set them aside, in a bag, hoping that since they haven't been on the head long (and not running at all) they might spring back to seal a standard valve. It will be a couple of weeks before I have the other head coated, so maybe there is hope... **************************************
