Home > Ebay items For Sale > 7 port
Gavin Wakely
Member #: 793
Just come across this on the bay
http://www.ebay.co.uk/itm/Crossflow-7-Port...=item35b20650e4
Thats the one i have
Dont forget imort tax and vat bump it right up and it needs a fair bit of fettling to fit
alaskanow0
Member #: 8466
Mansfield
Mine cost about £1500 after cost of new valves, porting, benchflow work etc. I later swapped to the SC 7 port head with better results.
Edited by alaskanow0 on 5th Oct, 2013.
They're cheap initially, but they are very crude & require a lot of work to get them to a decent standard. The one in the advert only has 33-29mm valves fitted to.
After all that work required is done, your better off with the SC head which comes off the shelf with bigger valves & has 99% of the work done for you.
Phil.
Johnny
Member #: 6926
Accrington
True, i have one in its unmolested state.
It needs a lot of working doing to it.
id say at least £300 worth
i got mine for £900 after taxes etc.
Phil.
