| Home > Help Needed / General Tech Chat > puff of smoke | |||||||
![]() 52 Posts Member #: 593 Advanced Member woking, surrey |
20th Jul, 2005 at 09:13:42pm
wondered if you lovely ladies and gentlemen could help me, on acceralation i get a puff of smoke out the exhust and on over run also sometimes when i putt my foot down it seems to miss fire could these be linked help needed many thanx era turbo - not even the mrs gets to drive it |
20th Jul, 2005 at 09:15:59pm
overfueling? Crystal Sound Audio said:
20th Jul, 2005 at 09:24:48pm
Smoke on overrun is typically worn valve stem seals.
20th Jul, 2005 at 11:01:21pm
if the fueling checks out OK???
Edited by BENROSS on 20th Jul, 2005.
21st Jul, 2005 at 06:31:02am
also this can be oil from the dash pot if you put to much in. just another thought always looking for them bigger bunches of bannanas |
21st Jul, 2005 at 09:28:29am
100% valves/guides seals. If it does it on overrun, it's always the guides.
21st Jul, 2005 at 10:38:46am
If it smokes on idle,jack the front of the car up to see if it's the guides or not (i think)??
21st Jul, 2005 at 04:55:52pm
i would be inclined to disagree vegard.
21st Jul, 2005 at 06:42:04pm
thank you lads alot will have my dad go out in it and ill follow no it hasn't done moon milege and its been sitting for a while only 20k on the clock from 1989 and the mot's say the same thanx again era turbo - not even the mrs gets to drive it |
21st Jul, 2005 at 08:14:22pm
Smoke on overrun is usually valve guides, as the vacuum pulls oil down through the worn guides or stem seals.
21st Jul, 2005 at 11:18:18pm
would be nice for an update tom if ministeve replaced the valve guides & seals
22nd Jul, 2005 at 04:04:13pm
cant touch it till the 3month warnity is up have like the bloke i brought it from no there a problem he's looking into it will keep you gents post thanx again for your much needed help era turbo - not even the mrs gets to drive it |
23rd Jul, 2005 at 10:56:17pm
had this on mine if you remember rolling road pics, randomly sometimes when idling when warmed up it owuld do it too until you reved it slightley, sorted it out with some new valve stem seals Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
26th Jul, 2005 at 05:08:19pm
update on the probs, well changed the oil was pretty dirty no more smoke or any probs on the engine front not just losing water, about a inch after a long drive of varied driving, have water marks on the top of the rad and on the aux rad but cant find any splits, i have standard rubber pipes any ideas
26th Jul, 2005 at 06:17:36pm
All i can place the smoke down to is
