| Home > Help Needed / General Tech Chat > megajolt | |||||||
72 Posts Member #: 10523 Advanced Member PALM BAY FLORIDA U S A |
29th Oct, 2013 at 02:36:56am
Do you still use a distributor if you are using the megajolt system ? |
29th Oct, 2013 at 07:26:40am
No. It replaces the distributer entirely.
In the 13's at last!.. Just |
29th Oct, 2013 at 01:15:38pm
So there is just a blanking plate to cover the distributor hole. I guess this setup is basically a crank fire system. and I guess I will just need a lap top to make adjustments. can you tell me are there any basic programs maps for a turbo car as in fuel n ignition to get started ? |
29th Oct, 2013 at 01:25:38pm
Search.... On 11th Feb, 2015 robert said:
29th Oct, 2013 at 01:29:37pm
On 29th Oct, 2013 era mini mark said:
Do you still use a distributor if you are using the megajolt system ? IMPORTANT! If you remove the distributor you MUST also remove the distributor drive gear. Leave it in and it will fall out into the gearbox and cause big problems.
29th Oct, 2013 at 05:19:15pm
worth searching and reading on what a mj does |
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
29th Oct, 2013 at 09:00:03pm
good starting point
On 29th Oct, 2013 philc said:
worth searching and reading on what a mj does What the mind can conceive the mini can achieve
