Home > General Chat > Lathe projects.
Star Mag
Member #: 375
Leicestershire
I have recently got hold of a small lathe that I hope to teach myself to use. I have a good starter set up with most of the basic tools that I should need for the moment. I've been swatting up on basic maching practice and now have the lathe set up ready to go.
I have the plans for some basic starter project but I was wondering if anybody has any starter project ideas.
My Dad is keeping me on the straight and narrow as he has been model engineering for as long as I can remember. He is spending his time in the workshop tuning two stroke model car engines at the moment from 1.5cc to 10cc.
Ron
Stepped shaft between centers (largest dia in the middle) is one of the best starter project... That teaches you a lot more than you realize.
Plumb bob, spark plug, have the scematocs as well somewhere I could send you?
The first thing I made with my lathe after I converted it to CNC was a dizzy bung. Simple but useful.
http://www.ebay.co.uk/itm/MINI-LATHE-TOOLS...=item51a8acc33d
Amp
Member #: 7856
I'd say a set of swaging tools, they will help with TM disease!
cam bearing tools.
gudgeon pin removal tool.
washer for punning the cv joint in.
piston ring compressor
afrance2905
Member #: 10512
whitby, north yorkshire
I don't use lathes but the lad at work do and got them making me a few bits like top tower bolt spacers and some little bits of the steering column
graemec
Member #: 1424
Carnforth, Lancs
'Washer for putting the cv joint in'
I'd buy one of these if you could do them for less than MS.
Couple of other things I could think of -
-Horseshoe shaped special tool for knocking the main bearing out of the gearbox
-Synchro ball retainer ring for rebuilds
- Seal and bearing drifts
What's this washer for??
graemec
Member #: 1424
Carnforth, Lancs
Seating the bearings on the CV before fitting the cone washer. The cone washer can 'nip up' before being fully home otherwise.
http://www.minispares.com/product/Classic/...arch/classic/cv washer.aspx|Back to search
With regards to the washer, I've never used one and never had a problem, and others swear by them. Swaging tools is a good shout, you could even make a slide hammer.
Never heard of that, I'll have a look in the book
I've also never needed one. £4.50 for a large washer!
To be fair you'd probably just have those laser cut from suitable thickness plate rather than machine from solid.
Ben H
Member #: 184
Melton Mowbray, Pie Country
I too have just got a small lathe and am thinking of a few projects.
As an apprentice we made some drifts and a centre pop. Need a knerling(sp) tool really though to make a nice job.
http://www.twin-turbo.co.uk
Star Mag
Member #: 375
Leicestershire
There is some good ideas there to get me started! Hopefully I will start making some swarf this weekend!
lee.pb
Member #: 9199
Lancashire
pictures of your progress would be interesting, the last time i used a lathe i nearly lost a finger :(
You know that big turny thing that you put the piece of metal in.... you shouldn't touch that...
lee.pb
Member #: 9199
Lancashire
the lathe was off, was told to clean the swarf out the bottom.
no ppe / training and 16 at the time.
ended up with some swarf around my finger and pulled hand out, cut 3/4 round index finger *angry*
2 operation to put nerves and tendons back together, still not right 20 years on
Ouch!
Ive actually done the same, but no where near as bad, and fortunatly no lasting damage.
lee.pb
Member #: 9199
Lancashire
wont be doing that again.
just have 20% feeling in finger now but still works fine
Ouch!
Edited by lee.pb on 2nd Nov, 2013.
Making a stepped shaft is the best thing to start with. Do a drawing of multiple steps giving set diameters and lengths for each step and set yourself a tolerance to work to (.02mm is usually the tolerance to work to when training) and if you can work to that then anything else will seem easy.
Centre punches are good for practicing machining shallow angles and getting used to the compound slide.
Die holders and handles are a good exercise, as you'll need to use a boring bar, and practice cutting threads for the handles, even if you're just using a die for the threads. And it's a good tool to have too!
Just think of tools you need, and try to make them, bearing pullers, punches, swagers etc.. Are all usefull and at least you'll get use out of your practice pieces.
Also, practice threading (using the change box) as cutting threads is somethinng that definately takes practice, but is so useful.
