Home > For Sale > SC Throttle body (50mm) Plus Injection Kit
This is the injection stuff from the Sabre Sprint. I was saving it for use on the Nimbus, but other projects mean the money will be better used elsewhere.
Included is as in the photo:
50mm SC Throttle body on a metro turbo manifold (with fuel rail and 2 x 440cc injectors and TPS)
SC throttle cable
Fuel pressure regulator
Injection fuel pump and filter
MS1 ECU (currently programmed with turbo fuel and ignition map from Sprint. I'll supply the relevant software on a CD)
Magneti Marelli IAT sensor (blue pipe has a fitting to mount it)
Crank sensor and plug with shielded cable
EDIS and plug
I'll also send the wiring diagram for the Sprint that I drew.
The main things missing are the coil pack, the water temp sensor, wiring and a few of the plugs (such as for the injectors etc, all easily available). when wiring it all up you may also want to use a a few relays.
So this is not a plug and play complete system, but most of the bits you'll need are there and the missing bits are easy to get. a bit of soldering, some crimping and bobs-your-knob you'll have an nice injection system.
£450 posted. I can send abroad but postage will be extra.
Alex1340
Member #: 111
Loughborough
Would you be interested in splitting the kit?
I need an ECU, fuel pump, reg etc but i don't want the throttle body or manifold.
Thanks
Charl-1275
Member #: 10586
I would take the throttle body, only problem is i'm in Cape Town.
Sorr, this is all aready sold.
bhpmini
Member #: 8907
Will u split ? If so what u want for the throttle body and cable ?
ms2 is beyond me come back carbs all is forgiven why did I decide to modify a spi mini *frown* to late to turn back now so please put up with my stupid question and humour me
