| Home > Help Needed / General Tech Chat > Clutch siezed solid | |||||||
21st Jul, 2005 at 04:26:35am
Just got my mini off the boat, engine started OK but the clutch pedal is solid, no movement at all. I tried wacking the arm a bit but nothing is shifting, anyone got any ideas on how to loosen this? I Think the hydraulics are OK and Its a Verto. website:- http://www.terryhunt.co.uk
21st Jul, 2005 at 08:06:24am
Is the clutch engaged or dis-engaged? I'd guess you pressed the pedal once then it went hard?
21st Jul, 2005 at 08:40:11am
ive had this a couple of times with cars i have bought that have sat around
21st Jul, 2005 at 08:40:39am
You might find that it is the release plunger seized in the clutch housing cover. I have come across this a couple of times before. This, and the pivot on the release arm are about the only places that run close enough fits to seize up. What has possibly happened as well is that by pressing the pedal, you have managed to shift it outwards, but it will not return. Further pressing of the pedal causes the slave cylinder piston to reach the circlip at the end of its bore, hence the pedal goes solid as a brick!
21st Jul, 2005 at 10:41:19am
think id be whipping the clutch cover, slave etc off and see what happens, not a masive job and will give you a piece of mind |
21st Jul, 2005 at 02:22:17pm
OK thanks guys, it did indeed go down a bit the first time, but not all the way. I am not sure if its engaged or not as theres still a wheel off to get the tyre repaired I guess I could jack it up and find out. I have soaked it in WD40 and will take off the slave tonight, check that and then apply a bit of brute force. website:- http://www.terryhunt.co.uk
21st Jul, 2005 at 02:25:32pm
By the way, is the drivers door glass SUPPOSED to fall out through the big rusthole at the bottom of the door??
21st Jul, 2005 at 02:57:34pm
On 21/07/2005 14:25:32 Turbo Tel said:
By the way, is the drivers door glass SUPPOSED to fall out through the big rusthole at the bottom of the door?? Yes, no worries, all quite normal.
![]() 2102 Posts Member #: 432 Post Whore Swindon |
21st Jul, 2005 at 03:12:08pm
quick release window lol i like it |
22nd Jul, 2005 at 04:25:49am
Ok
