| Home > Technical Chat > Alloy caliper pistons | |||||||
![]() 334 Posts Member #: 6647 Avon Park Class B winner 2010/11 milton keynes |
26th Nov, 2013 at 10:03:08pm
Anybody know if these fit minispares alloy 4 pots? Can't find any sizes on there website. I can find some at Jon speed but these are cheaper
26th Nov, 2013 at 10:44:57pm
I would guess theyre the same size as Metro 4 pots, in which case they would fit Minispares but Id email and ask about the Metro fitment I seriously doubt it! |
27th Nov, 2013 at 12:02:09am
Speak to min- its
27th Nov, 2013 at 08:34:29am
You do NOT want aluminium alloy pistons in your brakes.
![]() 178 Posts Member #: 10196 Advanced Member |
27th Nov, 2013 at 09:08:31am
On 27th Nov, 2013 Vegard said:
You do NOT want aluminium alloy pistons in your brakes. 1. The transfer heat into the brake fluid like motherfuckers. 2. They wear out Fit stainless steel pistons. Agreed, also the corrosion factor |
27th Nov, 2013 at 10:02:39am
Yes I do. The heat transfer is not a big issue to me and don't think they will wear down because of the mileage I do
Edited by Chris Dillow on 27th Nov, 2013. |
174 Posts Member #: 9128 Advanced Member |
27th Nov, 2013 at 11:33:54am
I got a set of Metro stainless pistons when purchasing my minispares 4 pots. And fitted them whilst fitting the spacers to run vented disks. |
27th Nov, 2013 at 02:07:45pm
car is just for drag racing, the fuel tank is about the same size as a bottle of coke! Drives
27th Nov, 2013 at 07:13:56pm
Well I've bought them today so we will see |
31 Posts Member #: 9334 Member |
30th Nov, 2013 at 05:09:06pm
Should've asked about replacement seals. I reckon they will all use the standard Metro items. Same seals, same pistons. Any weight saving will be negligible, if at all. You could use less steel as it's stronger. |
