| Home > General Chat > Sierra Cosworth | |||||||
29th Nov, 2013 at 03:13:46am
So, here I am for no reason thinking about nothing, and then I realised it's 2013. Which means 1998 sierra cosworths (4dr) are now 25 years old. That probably doesn't sound like much of any importance, but it means they can be imported over here...
Edited by turbodave16v on 29th Nov, 2013. On 17th Nov, 2014 Tom Fenton said:
29th Nov, 2013 at 04:53:41am
2wd, make it quick no one has one in the states, make it a rs500 look alike or something girls will love it. Drives
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
29th Nov, 2013 at 05:20:30am
2wd thats had a few quid spent on it with big bhp as above rs 500 great looking motor Done now needs redoing lol |
29th Nov, 2013 at 06:47:57am
2 doors are lots of money Dave, and certainly not 6k, double that at least I would have thought for the very lower end of the scale |
29th Nov, 2013 at 06:57:07am
I definitely get the attraction Dave. In the 90's my father was quite heavily involved with race and rally preparing Sierra Cosworths so as an impressionable youth I spent quite a lot if time as a passenger sideways in Cosworths, so I've a definite soft spot.
![]() 1043 Posts Member #: 10424 Post Whore Swansea boyo! |
29th Nov, 2013 at 07:19:58am
Do you mean 1988 or 15 years old..?
On 29th Nov, 2013 TurboDave16V said:
So, here I am for no reason thinking about nothing, and then I realised it's 2013. Which means 1998 sierra cosworths (4dr) are now 25 years old. That probably doesn't sound like much of any importance, but it means they can be imported over here... You know where I'm going... But is this the stupidest thing you've heard? If i climbed in one tomorrow, would i be as disappointed as when i bought an SD1 Rover Vitesse (great to look at, great sound, but not much else)? What would i need to set aside for a reasonable 2wd model? Six grand? Or should i just go for a 110 or 127 crew cab defender... I think the defender would be more practical and probably have higher resale value... But it isn't a Cosworth. They don't die, they just get faster! |
29th Nov, 2013 at 07:34:51am
Dave , as Carl's said 3drs are silly money now , your looking at 15k +
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
29th Nov, 2013 at 07:52:42am
One of my mates has 2 sapphire cosworths, one running 28 psi and the other is a standard Andy Rouse cosworth.
29th Nov, 2013 at 09:09:31am
1998 must be a typo, they stopped making them early 90's...
Edited by Rod S on 29th Nov, 2013. Schrödinger's cat - so which one am I ??? |
29th Nov, 2013 at 01:17:46pm
Sorry all, I meant 1988.
29th Nov, 2013 at 03:00:24pm
My 2p? Shit cars to drive and utterly dissapointing if your used to modern cars in terms of both performance and percieved build quality. Look amasing tho. Import a shell and stick a v8 in it. turbo 16v k-series 11.9@118.9 :)
29th Nov, 2013 at 03:13:18pm
You've got to buy one because you want one for what it is, not for performance.
29th Nov, 2013 at 05:13:16pm
On 29th Nov, 2013 TurboDave16V said: I'm no expert as I've never had to do it for reliability reasons but the usual answer is to "long stud" it. Basically remove the inner six studs and drill out down to the bottom of the block and re-tap there for longer ones. It allegedly gets over block flex and partially mimics something like the K series (studs right through from bearing caps to head). The standard gasket is pretty robust (same design as a BK450). I've only ever changed one gasket but that was due to a head change after 14 bent valves..... never buy a "competition" belt when the standard Ford one works fine...
After 25 years has anyone come up with a reliable head gasket design that doesn't cost an arm and a leg? On 29th Nov, 2013 TurboDave16V said: Dreamers, obviously, and fools who occasionally buy.... Not much different to the Mini world ?
Also, seems that anything "sierra cosworth" on Ebay is still damn expensive - for what it is, or is that just dreamers lol. Schrödinger's cat - so which one am I ??? |
![]() 178 Posts Member #: 10196 Advanced Member |
29th Nov, 2013 at 06:50:27pm
my mate fit a group A one to his 400bhp rs500 replica, blew it the same day, and it was fitted properly, and driven by his girlfriend so shows the reliability.
29th Nov, 2013 at 06:51:50pm
On 29th Nov, 2013 evolotion said:
My 2p? Shit cars to drive and utterly dissapointing if your used to modern cars in terms of both performance and percieved build quality. Look amasing tho. Import a shell and stick a v8 in it. I'd largely agree. Except I wouldnt waste the money importing one to stick a V8 in ! They are old cheap and basic designs inside and out. In the UK they rust just like every other old car. Performance is moderate at best. In 4x4 form the gearboxes are chocolate. Unless you buy a very good example, they will be tired everywhere, interiors falling apart etc. Really....I'd have to ask why you'd actually want one ? Nevermind wanting one to the extreme you'd consider importing from thousands of miles away ! I'm not saying that if you found a really nice example they are terrible cars. Because a good one really can be a great looking car, and if you spend several thousand on them, could actually be enjoyable to drive too. But for that to happen you're well into 5 figures in UK £££ Also...are you talking 3 door cars, or sapphire ? The 3 door never was 4x4. Really...if it's a 3 door you want. Just buy a Merkur and make it look like a Cossie...then stick a proper V8 into it Edited by stevieturbo on 29th Nov, 2013. 9.85 @ 145mph
29th Nov, 2013 at 07:41:58pm
I think you have your answer Dave.
29th Nov, 2013 at 07:55:27pm
29th Nov, 2013 at 10:19:22pm
mate did a trackday on wednesday at oulton park and followed a cosworth for a couple of laps What the mind can conceive the mini can achieve
29th Nov, 2013 at 10:44:19pm
As a kid I always wanted an escort cossie, I gues my daily would smoke it, shame but true I run a supercharger and I don't care the TB is on the wrong side.
29th Nov, 2013 at 10:49:10pm
This posts reminds me of my fondness for cossies in my childhood, and although not a cossie my uncles boss owned a sierra xr8. 5.0 v8 from south Africa and I was told it was one of two in the country and made in very limited numbers. I wonder if theres any left today? -MINI CLUBMAN 1380 TURBO- |
29th Nov, 2013 at 11:25:55pm
It all depends if you want it because you simply want a Cossie, despite it's many failings and the huge cost involved.
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
30th Nov, 2013 at 12:32:56am
My prefference which is irrelevent, I would rather have a fucked breathless 1.6 pinto ex sierra mini cab on interstellar mileage, that's been spunked in liberally by an old tramp than own a defender. But if you bought a moonstone blue late saph cossy, I would most probably have a trouser accident my self!
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
![]() 76 Posts Member #: 9169 Advanced Member Cape Town, South Africa |
30th Nov, 2013 at 05:29:20am
On 29th Nov, 2013 T3Tone said:
This posts reminds me of my fondness for cossies in my childhood, and although not a cossie my uncles boss owned a sierra xr8. 5.0 v8 from south Africa and I was told it was one of two in the country and made in very limited numbers. I wonder if theres any left today? Sierra XR8 was my dream car when I was young, had a 5.0 mustang engine only 250 made. Some good rust free ones I see advertised for sale every now and then |
30th Nov, 2013 at 02:46:28pm
On 29th Nov, 2013 Tom Fenton said:
You've got to buy one because you want one for what it is, not for performance. Exactly, that's why I still have mine. An icon of a bygone age - but still not too bad. I finally got two tickets (legit, Ticketmaster) at 10:03am yesterday for Monty Python at the 02. Same reason. Schrödinger's cat - so which one am I ??? |
