Home > Help Needed / General Tech Chat > your going to hate me but m45 on a std 850?
charlieb150
Member #: 9931
brighton
Hi again I currently have a few spare engines around and a supercharger so am going to supercharge the 850 , it has a low cr from std about 8.3-1 ? How much boost is ideal. :). Not to bothered if it lasts 5 mins
None.
anything above 10-12 psi is a waste of time with a suck through is a waste of time.
I say 10-12 as it will depend to a small extent how hard you rev the motor.
charlieb150
Member #: 9931
brighton
To be honestcits just so i can have a little bit of fun and be able to stay with traffic so im getting a bottom pulley sorted the will bolt it on and set it up
What's the cam profile on an 850? Might be worth changing it for a 1275 of 998 standard one.
Otherwise go for it I think 5 or 6 psi would net some acceptable power. My calculations show 1:1 pulley ratio will give around 10psi (with an MG metro cam), but this does not account for losses.
BTW I was just being facetious :)
I seen Shorrock charged 850's before which apparently worked well.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
sounds like a few minutes? hours? days? of fun strapping a blower on an unknown engine
nah im sure its doable on the cheep to be somewhat reliable and make an 850 make enough power to move
charlieb150
Member #: 9931
brighton
Haha it is just to experiment really so its std except for some high lift rockers as this was my backup emgine :) but now have another in the pipeline
charlieb150
Member #: 9931
brighton
Anybody reckon i could get away with a hif 44 on the 850 rather than a hs 4 thats on it on being as i have one
charlieb150
Member #: 9931
brighton
Rammie2000
Member #: 10190
belgium
I had one on a standard 998... was a bit overkill
It worked well on my 998 when I first put the charger on..
charlieb150
Member #: 9931
brighton
Well it will save me some money so worth a go :)
Chalkie
Member #: 9764
Northamptonshire.
Go for it m45 roughly puts out 10 psi of boost standard pulley
Not sure how it works out on a classic mini running our size bottom pulley,
-21% reduction with a +2% bottom pulley on a bmw mini gives -23% reduction most you can get not sure on the BHP figures not man people done it
imo dont bother it will end in tears very quickley for the effort you will put in.
sorry if you dont want to hear this
charlieb150
Member #: 9931
brighton
I may well last seconds but just going to give it a go
whats the worse that could happen?
think of the experience you would gain at the least
with about 6 psi you'll up the wheezy asthmatic 850 from its 38 or so horses to maybe 40 at a push, with 10-12 psi you might crack 50hp.
obviously you might get better returns with a better head and exhaust system,
I'm guessing you don't want to touch the bottom end, so will be sticking with the std cam, but be aware that the 850's don like hot cams and heavy valve springs as they don't have cam bearings.
the only other thing I'd say is I don't think the pistons are particuarly strong, I reckon they will fall apart if you buzz it too much, or if you put too much power through them, however I cant see them having an issue till 50hp.
Give it a go, a lot will depend on if the engine is ok to begin with and how you drive it. My 998 was build in 69 and I charged it for 5 years before deciding I would like to have a go at building an engine.. But that was for the experience of building my own rather than my other one being knackered..
charlieb150
Member #: 9931
brighton
I will keep you posted will be on the rollers over christmas all being well but i am planning a 16 v build
Chalkie
Member #: 9764
Northamptonshire.
the 850 i stripped recently had cam bearings in it
think the early ones didnt come with cam bearings don't hold me to it.
Chalkie
Member #: 9764
Northamptonshire.
http://www.ebay.co.uk/itm/Shorock-Supercha...=item3f2d9f8da0
It's only the centre bearing they don't have.
Chalkie
Member #: 9764
Northamptonshire.
Ah never seen the centre one in there, just pulled cam out seen oil pump engine and timing end didnt have block off the box to see right inside
