Home > Help Needed / General Tech Chat > Lower dash rail - how structural?
steve w
Member #: 1917
AKA chargedzetec
As title, I'm thinking of cutting the dash rail, and the structure forward of it out.
Mounting the column on the cage, and gauges in a pod.
Thoughts??
It's so flimsy it cannot be structural surely,
c arl
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
in no engineer but id stay away from it unless the cage becomes the structure front to rea side to side in the car to replace it and support the surrounding body
perhaps some much more experienced guys can tell me im a fool and say what might be better haha
Ive always been unsure on this but decided I am going to make an aluminium one during my rebuild
steve w
Member #: 1917
AKA chargedzetec
My thoughts exactly.
I mine, the column has never really been that stable, as it all feels a bit weak.
Thought I'd better check before cutting.
c arl
lee.pb
Member #: 9199
Lancashire
I would of thought that if the roll cage has a support between the front legs to allow the colume to be mounted it's probably not required if the cage is tied into the shell.
But dont quote me on that, my mini has both.
100ev8
Member #: 9138
wolves
i brought a turbo mini ages ago that had a bump on the o/s door/a panel and bit of sill.
n/s door gap had opened up but i thought it was just the front over and a bit of pushing and pulling i would get it back
dam i was soooo wrong
the lower dash rail may be a bit flimsy but it had pushed and twisted the n/s flitch/a panel over by about 5cm
leave it in unless you cage it
Edited by 100ev8 on 26th Dec, 2013.
http://www.fishfight.net/
afrance2905
Member #: 10512
whitby, north yorkshire
look forward to seeing that, ive cut mine out for the bulkhead box but will be replaced with rollcage, carnt see it been of much use but will add a little bit of strength
I will be removing mine and using the cage for coulomb mount, dont see the point in it apart from to make a dash.
Well I don't se it adding much torsional stiffness because of where it is. All the front strength is in the large box section across the front bulkhead. So for my money, remove the lower dash rail, but keep the bulkhead box section and don't fit a turbo box.
Has anyone removed it in the mob prods Will
carl
I'm removing mine because it's mangled, putting in a bit of box across where it was to mount my steering column and heater to though instead. Should be a lot tidier behind, and I'll probably drill holes in two sides to keep the weight down of the box.
Chalkie
Member #: 9764
Northamptonshire.
I agree round the steering mount it is pretty damn flexiable. but that is just the backing panel is the bit at the front keeping it stiff?
Me. But I have one in the garage to rivet in if anyone complains. By the definition of unitary in the Blue Book it is not part of the unitary construction.
carl
wolfie29177
Member #: 476
The Black Countraaaaay
It is structural but badly specced. Basically because of the minis 'unique' construction the dash rail is used to tie the 2 sides together and reduce scuttle shake but to be honest I cant see it doing either of those. A well put together roll cage thats welded in will make the shell a hell of a lot stiffer than the dash rail ever could
Masturbation is not a crime its a hobby
