Home > For Sale > Parts for turbo engine build for sale
james753
Member #: 10321
Hello All,
Thinking of selling most of the bits I have gathered / hoarded as I am never going to get round to building a turbo engine *frown*
I will list what I have, and am open to offers.
Standard Rockers
12G940 Head - pitted chambers and seats - has been dipped, striped and cleaned so ready for machining - no visible cracks or broken studs.
Pre A plus Block Standard bores and +.10 crank
Pre A plus gearbox
Full pre A plus gearbox rebuild kit, strengthened layshaft x-pin diff. No Crown wheel and pinion.
21253 pistons (+.20) with 13cc dish machined in top. Attached to rods with rings and new bearings.
Pre a plus bell housing.
Peugeot 307 diesel undercrown oil jets
Brand new oil pump.
Straight cut drop gears - standard ratio unused, very slight surface rust - about to go on ebay....
Minispares Gray clutch pressure plate - done about 1000 miles.
Will also throw in duplex timing chain, timing plate, cam plate, a british leyland 544 profile cam, some new core and gallery plugs, central oil pick up - brand new, and a metro turbo plenum. (and other bits I find!)
MEGAJOLT box, ford edis, and some leads!
Looking for £650 the lot - well worth it if you add up the value of all the parts - pistons, x-pin dif and drop gears never fitted. I am open to offers.
James
I forgot to mention - the gearbox is in bits, all labeled and in bags.
I am located in Chester as it is all pick up only - I am prepared to drive to the M6 and meet you at a suitable location.
Edited by james753 on 1st Jan, 2014.
svrdaniels
Member #: 3600
Gateshead
Is the block on Standard bores? Where are you located?
james753
Member #: 10321
Yes it is,
The pistons would give 1293cc, but the block is not bored to match yet.
I'm located near Chester, but am prepared to drive a little to meet you if that helps.
James
Edited by james753 on 30th Dec, 2013.
james753
Member #: 10321
I've also found a minispares gray clutch pressure plate, so that's thrown in too.
It's basically new having only done about 1000 miles
James
james753
Member #: 10321
And found I'd collected parts for a megajolt build too! So included for an extra £50 is the megajolt box, a ford edis, some plug wires, and a machined pulley for the crank - all this is a bargain at this price - I must be mad!
James
ahob2134
Member #: 10708
would you sell the megajolt on its own ?
james753
Member #: 10321
Pm me an offer - I would prefer to sell the lot as a whole though.
I have someone interested in the megajolt already too, but first refusal and it goes to you.
James
tadge44
Member #: 2500
Buckinghamshire
If you do decide to break I would be interested in the pistons - and I dont need the rods.
james753
Member #: 10321
Some pictures up.
http://s292.photobucket.com/user/semaj753/...?sort=3&page=1#
Some parts are covered in grease to protect the faces, and so marks that look odd may well be grease not scoring or anything else.
Anything you want clarifying ask!
The oil pump is a turbo type brand new in box.
James
Edited by james753 on 4th Jan, 2014.
100ev8
Member #: 9138
wolves
link wont work for me
http://www.fishfight.net/
james753
Member #: 10321
Link edited sorry
WRLondon
Member #: 8636
Surrey
How much for this part? *hehe!*
Reading up on RTS Clutches
james753
Member #: 10321
Couple of pints? or swap - what have you?
HA!
Baz_rsp
Member #: 10521
Aberdeen
You still got all this?
Flat oot like a dukes fit!
Steve A
Member #: 7876
Walsall West Midlands WS1 2DW
No but I have! not keeping it all though to b honest as I only wanted the early block, crank and gearbox to be honest. I might sell the straight cuts, pistons etc.
Patina=old and knackered and won't clean up
adzn3k
Member #: 10715
trelawnyd north wales
Pm me price on pistons
Baz_rsp
Member #: 10521
Aberdeen
On me price of drops please.
james753
Member #: 10321
Yes, now sold to Steve!
Cheers Mate
