Home > Help Needed / General Tech Chat > n/a 1380 c/r help and advice
eden7842
Member #: 8852
leicestershire
Doing some maths for a mates 1380 and just want some help, it's a stage 5 head and a swiftune 310 cam. So we believe that we need a c/r of 12.5;1
So far I've worked out around 9.2
Heres the cc with some stock measurements form turbo-mini.
Dish 11
Head 23
Gasket 3.8
Ring land 0.8
And the deck hight is 27 thou down the bore.
Thanks in advance for for any help
welshdan
Member #: 1111
s wales
A stage 5 head is likely to have chambers of 20cc or less on an off the shelf head from one if the usual suspects. Also if using aftermarket pistons you need to consider the dish. Lots of variables. You need to look at some off the shelf part values and take it from there
Id deck the block so the pistons are only 10 thou down and go from there, also check all 4 pistons are the same height
Headgasket wise I believe an Af470 has a compressed volume of 2.8cc if that helps matters.
ususaly on a build with a cam like this you'd use 6cc or less dishes,
with the 11's your gonna have a hard time getting it up high enough unless you can skim the head a lot, in which case watch out for valve to piston contact.
eden7842
Member #: 8852
leicestershire
Il get him to check the spec on the head.
Will do that Paul thanks
And its a bk450 we use
Was thinking the 11cc pistons would be too much
Edited by eden7842 on 30th Dec, 2013.
With the figures you've given there 9.2-1 is correct. You're not going to be able to get 12.5-1 with those pistons though. Decking the block to leave no volume & skimming the head to 20cc will still only give you 10.8-1.
You need flat tops.
Phil.
eden7842
Member #: 8852
leicestershire
Thanks Phil, Ive just done some maths with flat tops and that'll get it straight up there
eden7842
Member #: 8852
leicestershire
What affect would the low c/r of had on this engine when running with this cam?
much less torque off cam , cam coming on later , worse mpg ,less power all the way up .
I would run 12.5 to 13:1 on the rd with v max fuel with that cam .
eden7842
Member #: 8852
leicestershire
Before it came out it never ran right, almost like a misfire?
wrong plugs?
eden7842
Member #: 8852
leicestershire
I believe he had bpr7es that's right with megajolt?
Trust me, it'd run like SHIT!!
Either change the cam, or get some 6cc pistons.
eden7842
Member #: 8852
leicestershire
Looks like we're going flat tops and deck it to 10thou
Use Omega 6cc offset pistons
eden7842
Member #: 8852
leicestershire
I can only seem to find 7cc Paul?
Thats it - 7 not 6. Thats what I use
eden7842
Member #: 8852
leicestershire
Ah that's kool, what cc is your head if you don't mind me asking Paul? And also out of interest, why not flat tops?
Not major clued up on high power n/a tbh
Ive no idea what cc my head is tbh. It was years ago.
Its all to do with chamber shape
I meant 7 as well. With flat tops you're screwed the other way around *wink*
