| Home > Help Needed / General Tech Chat > OT - Does anyone do stuff with wood? | |||||||
5th Jan, 2014 at 03:39:38pm
I'm putting together a homemade arcade cabinet for which I've bought a T moulding to run along the edges of both side panels. These panels are 18mm thick and have some tricky corners etc, so I wouldn't like to attempt it freehand with a Dremal for instance.
Edited by theoneeyedlizard on 5th Jan, 2014. In the 13's at last!.. Just |
![]() 1751 Posts Member #: 10190 Post Whore belgium |
5th Jan, 2014 at 05:01:29pm
your a bit far mate. otherwise you could use my machinery for that. you can do anything if you set your mind to it...
5th Jan, 2014 at 05:50:04pm
Would it be possible to post the bit?
5th Jan, 2014 at 06:08:30pm
the bit is for biscuit jointing i dont think they do them as small as 1mm though i think they are 4mm
5th Jan, 2014 at 06:17:39pm
3mm is the smalles and i have a blade that gos 2.5... but they are ment for a "toupie" dont know the word in english. big machine with vertical axel where you put the bits on. if it is for joining 2 plates cant it work with (again that englisch word..) http://www.staalimex.nl/meubeltechniek/ver...en-deuvels.html
5th Jan, 2014 at 06:26:41pm
a no sorry. its not for connecting the panels but for a slot along the edge. so you need a router and a bit right? allong with one of these. http://www.capellemanmachines.be/frezensets_hbm.htm
5th Jan, 2014 at 06:31:27pm
Why has simon not poped his face in and nic? Whats going on! Drives
5th Jan, 2014 at 06:44:01pm
My old man used to build these for a job he had 100s under his name. I have started posting on Instagram also my name on there is turbomk1golf
5th Jan, 2014 at 06:51:49pm
I've looked at the biscuit cutters but as you say, these aren't available this small.
5th Jan, 2014 at 06:57:19pm
1mm cutting disk? And a bit of free style cutting action ? I have started posting on Instagram also my name on there is turbomk1golf
5th Jan, 2014 at 08:35:18pm
I reckon so. In the 13's at last!.. Just |
5th Jan, 2014 at 09:02:23pm
http://m.ebay.co.uk/itm/161189818859 Say is it still separated? If so why not make a mold that is the size of the foot of your router bigger ( if that makes sence) and use a pin router bit like so you can easily follow the curves no danger of going out the line and cheap to lake a mold out of mdf plate. you can do anything if you set your mind to it...
5th Jan, 2014 at 09:04:36pm
Have a look for a mill slitting saw blade. Usually quite cheap, and I'm sure it would be an easy enough job to make some kind of arbor.
5th Jan, 2014 at 09:17:18pm
might be worth an ask at a local camper van conversion place. Somewhere that builds their own units, pretty sure they have the same type of moulding on the edges so may have the tools to do it for you. On 20th Oct, 2015 Tom Fenton said:
5th Jan, 2014 at 10:41:41pm
Thanks for the ideas. I've bought a slitting saw for £3. I think I'll lash something together so it fits to the edge of my bench. In the 13's at last!.. Just |
