| Home > Help Needed / General Tech Chat > duplex timing | |||||||
83 Posts Member #: 9728 Advanced Member West bromwich |
11th Jan, 2014 at 05:35:59pm
Just looking at buying a duplex timing set and mini spares do a lightened one and a stdbut both say road use only as I may want to quarter mile it occasionally which one do I use ?
11th Jan, 2014 at 05:54:57pm
They'll both be fine to use Neil, don't worry about that On 26th Jan, 2012 Tom Fenton said:
11th Jan, 2014 at 05:57:51pm
that's good then think ill go with the std one then and offset key to time it
11th Jan, 2014 at 06:10:09pm
It's probably just not meant for use at sustained high rpms On 26th Jan, 2012 Tom Fenton said:
11th Jan, 2014 at 07:26:17pm
To be honest, I'd just use the standard single row gears and chain and set the timing with offset keys On 26th Oct, 2004 TurboDave16v said:
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
12th Jan, 2014 at 08:41:35am
If you fit the duplex chain remember to modify the timing cover.
12th Jan, 2014 at 10:02:18am
If used on a highish revving engine, get the steel one. Iron is for standard engines. On 13th Jul, 2012 Ben H said:
12th Jan, 2014 at 08:17:38pm
well ive lightened and balanced all engine parts so I think it will be a bit of a revver so what steel one do you mean the one that's not lightened |
