| Home > Technical Chat > It doesn't want to boost | |||||||
26th Jul, 2005 at 06:51:06pm
I've started my car now, but when idling, the boost gauge drops to -9psi. I seem to recall that it should be 0 on tickover. On 13th Jul, 2012 Ben H said:
26th Jul, 2005 at 08:30:20pm
boost gauge needs to be mounted between the buterfly and the head in the manifold usaly were the servo mounting is (thats were ive got mine)
26th Jul, 2005 at 10:18:34pm
After taking her (him) for another spin, it's clear that it does boost. But, the boost gauge will not exeed 0psi even if it comes on boost. I can tell it's boosting as the fuel gauge rises as the boost gauge should do.
Edited by Vegard on 26th Jul, 2005. On 13th Jul, 2012 Ben H said:
26th Jul, 2005 at 10:23:24pm
Diameter of a hose should not affect the pressure transmitted along it to that degree. Hose bore will affect FLOW down it, but static pressure (as transmitted to a boost gauge) will not be GREATLY affected.
26th Jul, 2005 at 10:23:51pm
Have you plumbed it in after the one-way valve?
255 Posts Member #: 520 Senior Member nr hull |
26th Jul, 2005 at 10:25:22pm
ive got exactly the same prob on mine? ive also tried plumbing the boost gauge into the line from the plenum chamber to the regulator to see if it will at least show + boost figures and still nowt. reads below 0 on tickover and about .2bar on full boost in 4th, and thats at about 8 or 9psi i think. a slight amount more and the overboost valve opens which is 10psi standard isnt it?
doh! why did i start messing with it!
27th Jul, 2005 at 12:35:24am
have you got enough preload on the actuator as ths can cause probs as well as the waist gate not being shut properly.
27th Jul, 2005 at 09:08:11am
You should run a seperate line for both the DV and the boost guage.
AlexF |
27th Jul, 2005 at 09:17:45am
Well, as it is now, the gauge is definately connected to the inlet. The pipe going from thne inlet, into a T-piece which leads to dump valve and gauge. The thing is that on my last gauge it didn't show as much negative boost, and it was connected the same way.
27th Jul, 2005 at 09:29:02am
One way valve... to the servo or the emissions junk (think that red can thing Metro's had!).
AlexF |
27th Jul, 2005 at 09:51:02am
Indeed I can. How do I tell if hte DV is leaking? I've cot a valve that was included on the Cossie Intercooler. Could I plump that one on and see if there's a difference?
27th Jul, 2005 at 09:53:56am
take the DV off... its a crap noise anyway!
AlexF |
27th Jul, 2005 at 02:39:04pm
just block the dv off after the t piece using a g clamp or something simalar and try it if there is still no joy the clamp of the pipe to the actuator and give that a go but be carefull as you will get plenty of boost but at least this will see if the acuator is working properly or is set to light which can cause the waist gate to flutter and you loose boost, buy the way is doesnt need to move much for it to do this believe me.
27th Jul, 2005 at 03:06:03pm
maybe gauge is faultty, have you tested this on foot pump maybe? Team www.sheepspeed.com Racing
27th Jul, 2005 at 03:18:01pm
Thanks for the tips.
27th Jul, 2005 at 03:22:55pm
assumption is the mother of all fuck ups!
AlexF |
27th Jul, 2005 at 03:31:47pm
Jim's racetech gauge was doing strange things at Avon... On 17th Nov, 2014 Tom Fenton said:
27th Jul, 2005 at 04:10:05pm
yea, mine is now fauty after around 12 hours of use Team www.sheepspeed.com Racing
28th Jul, 2005 at 08:27:41am
Hm.. I'll try to bolt on the old one and block the dump valve.
28th Jul, 2005 at 08:33:33am
chatter!
AlexF |
969 Posts Member #: 47 Post Whore Not very sunny swanage |
28th Jul, 2005 at 10:25:16am
yeh, chatter may rock, but its kinda a exppensive noise!!! lol!! at least the chav sneezing is free! And on the 7th day........... God created turbochargers! |
28th Jul, 2005 at 10:48:39am
Care to explain nutter?
AlexF |
28th Jul, 2005 at 01:47:38pm
cant say i understand it completley.... but a quick search turns up this....
28th Jul, 2005 at 08:39:56pm
use a adjustable dv so it doesnt dump much air so you get less lag but a bit of gary boy wooosh.
28th Jul, 2005 at 09:12:02pm
I've now driven the car for the first time.. Once the turbo spools up, it stalls, and then completely dies.
