Home > Help Needed / General Tech Chat > Dry decking specialist components 7 Port head
alaskanow0
Member #: 8466
Mansfield
Anybody had any experiences dry decking the SC 7 Port. I plan on upgrading my current 5 port turbo build that's already running dry decked. I've tried, but failed to remove the plate on the clutch end of the 7 port head to look for a suitable place to drill for a adapter.
I know I could ask SC, but I'm sure I've read somewhere that Wilh as done this?
Mine is indeed dry-decked, well in as much as I have sealed the waterways in the block up (well most of them, I allowed some flow between head and block.
The end plate just comes off, there is no gasket, only sealant. Stop being gay and get it off.
I just used turbo phils adapters, with a slight modification. then I drilled and tapped the end plate.
alaskanow0
Member #: 8466
Mansfield
Ok Thanks Will, I just didn't want to damaged it. Ill man up
