| Home > Help Needed / General Tech Chat > Will a 0.40 grind remove the fillet radius entirely from an a plus crank? | |||||||
19th Feb, 2014 at 08:16:42pm
The 0.20 grind on the big ends has cut into the fillet radius, creating an ideal place for a crack to start.
19th Feb, 2014 at 08:28:10pm
I suppose it all depends on how much of the rad is left at the moment. 10thou a side isn't a lot to leave a decent rad. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
19th Feb, 2014 at 08:50:43pm
Probably displaying my ignorance again, but should the fillet radius not be re-formed if the crank is ground properly ? |
19th Feb, 2014 at 08:56:28pm
The radius has either been rolled off centre from the factory, or the crank has been ground off centre, meaning some radius has been cleaned up, some rolling remains and the transition makes a big stress point.. Will get a photo.
19th Feb, 2014 at 09:04:45pm
On 19th Feb, 2014 tadge44 said:
Probably displaying my ignorance again, but should the fillet radius not be re-formed if the crank is ground properly ? Yep, the wheel should be dressed to give the correct radii in the corners. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
19th Feb, 2014 at 11:51:49pm
imo have it done but have it nitrided
20th Feb, 2014 at 08:18:02pm
I'm going to get it crack tested, then stick it under the bed. Can always regrind to cooper s big ends if I ever use it again. On 7th Oct, 2010 5haneJ said:
126 Posts Member #: 10212 Advanced Member Sleaford Lincolnshire |
20th Feb, 2014 at 09:57:15pm
Give MED a call they may be able to help
21st Feb, 2014 at 01:18:21am
If there were anyone I'd talk to about grinding cranks, I'd talk to Simon at SMMC. I'm not sure where you are located but even send it to him from Norway. On 13th Jul, 2012 Ben H said:
