Home > Help Needed / General Tech Chat > miglia arch fitment?
calvint3
Member #: 132
ive just purchased a set of `miglia wide` arches but have no clue really of how to fit them?
thought about bonding them on with some sort of sticky something. but pretty sure that wont be a good idea unless i want to lose them somewhere.
has any1 or does any1 know how to fit them?
calvin
any help much appreciated.
cheers
SumpNut
Member #: 28
Most archs pop rivit on to the body directly..... dunno about ure's tho
1310turbo
Member #: 41
As sumpnut as said they are usually rivited on or bolted. you must have some pretty wide wheels/tyres to go with them!?
A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white|
calvint3
Member #: 132
yeah going for 8 x 13 alleycats if i can find the funds should be very wide and very low.
very nice!!!!!
or maybe you disagree?
1310turbo
Member #: 41
no i dont disagree, thats the beauty of the minim, you can make it what you want, and there isnt really any right or wrong ways, its what you want so its upto you isnt it, should look good with the miglia arches
calvint3
Member #: 132
cheers 1310turbo as soon as its a lil further ill get some pictures sorted and post em.
doesnt look all that but i will get somethin sorted. went out this morning to session it, bout five mins after i went out it started pissing it down with rain and still is.
as soon as it stops i`ll be out there.
calvin
