| Home > General Chat > What damper pulley for k hea | |||||||
25th Feb, 2014 at 06:10:50pm
As my old pulley was looking a bit worse for ware, I decided to buy a MED damper pulley with built in trigger wheel. It arrived today, and although it looks awesome quality, it's not going to fit because the trigger wheel is in the way of where my cam belt runs.
25th Feb, 2014 at 07:13:23pm
Med's supercharged one? I thought that was offset to clear the belts?
25th Feb, 2014 at 07:58:51pm
There's been a lot of debate in the past as to whether using the balance ring for the trigger is a bad thing or not. When you read into crankshaft harmonics, it would appear that while the outer ring does move around the true dead center, it' s by only as much as the crank flexes, in the opposite direction, which can be as much as 0.5 degrees (+- 0.5 degree).
25th Feb, 2014 at 11:37:46pm
To be honest, machining the teeth on the outer ring wasn't the concern. I just didn't want to start messing about with an expensive damper pulley if I didn't have to.
26th Feb, 2014 at 12:32:02am
I know of one pulley where the mass ring shifted, and threw the timing out. I never really liked this idea anyway, and that convinced me that this is best avoided. On 17th Nov, 2014 Tom Fenton said:
26th Feb, 2014 at 09:08:50pm
Well I decided to bite the bullet...MED trigger teeth are now a pile of swarf and it now has a new set of teeth jim Carrey would be proud of. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
46 Posts Member #: 8869 Member Porto, Portugal |
27th Feb, 2014 at 10:49:57pm
Hi Matty, you need to evaluate the fact of MED damper may be very close to the belt drive or even touching the belt drive...
Edited by Diogo Lima on 27th Feb, 2014. |
28th Feb, 2014 at 09:35:21am
that's looks fancy! What RPM range is the damper designed for? Team www.sheepspeed.com Racing
