Home > Help Needed / General Tech Chat > Which piston rings (now with pics)
madonminis
Member #: 9371
East Yorkshire
I have some omega cast +60 pistons and I've seen the piston rings on MED website at £105
Just wondering if there are any other options elsewhere I've not seen.
Edited by madonminis on 8th Mar, 2014.
Mr Joshua
Member #: 1954
Luton Bedfordshire
As long as you can match the rings exactly for size and profile you can fit what you want. Had to do this for my turbo build to fit my oe metro turbo plus 20 pistons.
Own the day
I'd just buy the omega ones.
Jawd
Member #: 10212
Sleaford Lincolnshire
Buy the MED rings, No brainer tbh
I always have the machine shop supply the pistons and ring sets after they have machined the bores.
Good engineering practice
Jawd
depending on how old your Omega's are will depend on which rings you buy, they are not all the same dimension.
There is always a custom ring set from Total Seal, conventional or gap-less varieties .
madonminis
Member #: 9371
East Yorkshire
Shit really. What do I measure to tell the difference?
Post a picture up. I found out the hard way that I had the old omega forged pistons, which use the cast ring set.
The most noticeable difference is that the older rings have a wider oil control ring.
madonminis
Member #: 9371
East Yorkshire
Pics with and without rings.
madonminis
Member #: 9371
East Yorkshire
If anybody wants to be a superstar and point me in the right direction as to what I need that would be awesome.
Matt
tadge44
Member #: 2500
Buckinghamshire
They look like the wider oil control rings, but as there is inly 0.5 mm difference measure them. From memory the wider ones are 3.5mm.
Yep they look like the the ones I have now. The oil control ring has tangs on the spring. The newer oil control rings are about 2mm wide and have a different looking oil control ring.
It looks like all cast omegas run the same rings from what I can see on MEDs website,it's only the forged that have different types.
Jawd
Member #: 10212
Matt
MED told me that my forged ones were supplied with some Japanese rings,
but as they machined the bores and supplied the pistons and rings at wasn't concerned
Jawd
