Home > Help Needed / General Tech Chat > K line K Liner Bronze guide inserts
skolawn
Member #: 69
Coventry
Any one have experience? They appear to be allowed in the rules for the racing Katie is doing, but cant find any details of anyone locally doing them, and their availability in 9/32.
Give me a shout can sort you out
I've never found them in 9/32. Ben, do you have them?
I like K-lines, they are easy to fit, cheap and good.
skolawn
Member #: 69
Coventry
cheers will do.
should be a week or so for i get another supply V will let you know
Earwax
Member #: 10368
Australia
I use them in road car and a historic group n mini, different valves of course, and i am not local ,,, but my experience with them is also good.. Cheers
What is the benefit of these guide liners over conventional bronze guides?
http://klineind.com/Valve-Guide-Liner-R-System.html
Easy to fit, and they don't wear out the head bore when changing regularly.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
do u need to bush the hole in the head? or are the valve stems really bit?
seems the guide is thin as compared to std guide
These fit inside the regular guide who is opened to house the liner.
skolawn
Member #: 69
Coventry
http://www.youtube.com/watch?v=xOaOTnpacV0 shows what it involves
Earwax
Member #: 10368
Australia
Supposed to be less likely to catch the valve stem - don't know if it is less expansion at temp or slipperyness of them.
skolawn
Member #: 69
Coventry
benefits, easy to fit, dont have to remove the old guide which can damage heads especially old fragile alloy ones. can have a tighter fit between valve and guide than traditional guides. oil is captured in the the liner by an interrupted spiral effect which lubricates but doesnt allow oil down to the port. (all from their PR) my interest is they are allowed for the class my daughter is racing this year and all other bronze type guides are not allowed.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
looks like a decant system
Iron guides and plated valves work well enough??
skolawn
Member #: 69
Coventry
V work Well enough? Katie will be racing in a standard class and anything that gives a small improvement and is allowed needs to be considered
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
i agree that anything thats legal and with in reach should be done if u want to be competitive
