Home > 998cc > 998 turbo dizzy
sam138
Member #: 10219
Will I be able to use a metro turbo dizzy on my turbo 998 , the spec is standard 998 with 12g295 head and mg metro cam going to run between 8-10psi . Does the dizzy need mods or can it be used at this psi boost . And can I check that this is a turbo dizzy AUU 1082 2001 42626J 0988.
Yes it can be used as long as you have an A+ block. It's far from ideal but will be safe.
tadge44
Member #: 2500
Buckinghamshire
It is not too difficult to mod a turbo dizzy to fit a pre A+ block.
I have done it on two occasions.
sam138
Member #: 10219
Ok thanks I have an A+ block just wanted to check that the serial number is a metro turbo dizzy .
